[Geoserver-users] WFS Cascading
Any documents about WFS Cascading Configuration ?
Thanks !
Ing. Fabio D'Ovidio
WebGIS Staff
Planetek Italia Srl
via Massaua, 12 - 70123 Bari - Italy
web : http ://www.planetek.it
e-mail : dovidio@anonymised.com
Well, WFS cascading is experimental, and not fully working at the
moment.
For example, cascading won't work if you try to cascade another
geoserver because of the namespace prefixes included in the
feature type names... it may work properly with other servers
that do not specify the namespace prefix in the feature type
name.
More info here: http://jira.codehaus.org/browse/GEOS-4
If you want to try, just download the WFS plug here
http://docs.codehaus.org/display/GEOS/Latest
and then provide it with the capabilities link in the
configuration, and enable gzip compression if the
server you're hitting supports it.
Please file jira issues if you stumble into problems
not already attached to geos-4
Andrea Aime
The WFS datastore works like most of the other datastores. Beyond that, I don't know much about it.
I've looked around for documentation on it, but it seems to be lacking. I will look some more, but I don't think any exists =(
Brent Owens
(The Open Planning Project)
Thanks !
Ing. Fabio D'Ovidio
WebGIS Staff
Planetek Italia Srl
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
It's still not totally up to speed. See: http://docs.codehaus.org/display/GEOSDOC/WFS+DataStore We've fixed a number of the bugs, but I don't think all of them. It'll work with WMS, but true cascading WFS isn't completely there.
Chris
Brent Owens
Thanks !
Ing. Fabio D'Ovidio
WebGIS Staff
Planetek Italia Srl
!DSPAM:1003,4553af7a131681219810056!
Chris Holmes
http://topp.openplans.org
Afaik the missing piece is to have cascaded type names in the format xxx:yyy turned into something that does not break GML.
But I was unable to reach consensus on what needs to be done, at least
on a practical side. There were talks about name mappings, but could
not convince the WFS maintainer that a nice switch to wipe out the
: is needed.
