[Geoserver-users] WFS Comparison operatos
hi everybody,
is it possible to encode a filter which does temporal selection ?
ie, uses comparison operatos on timeStamp field in a postGIS datastore ?
Merci !
Sébastien Geindre
DPREVI/AERO/DEV
sebastien.geindre __at__ meteo.fr
Sébastien Geindre a écrit :
hi everybody,
Merci !
Yes it is : <ogc:Between> does not seem to work...
but it can be done with <ogc:PropertyIsGreaterThan> and <ogc:PropertyIsLessThan>
and what about the time zone ?
which timezone geoserver use when it fills postGIS datastore through WFS ???
<wfs:GetFeature service="WFS" version="1.1.0" xmlns:wims="http://www.flysafe-eu.org/wims&quot; xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs
  http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
  <wfs:Query typeName="wims:ice_geom">
    <ogc:Filter>
      <ogc:And>
          <ogc:PropertyName>issue_time</ogc:PropertyName>
          <ogc:Literal>2006-12-14T12:00:13</ogc:Literal>
        </ogc:PropertyIsGreaterThan>
          <ogc:Literal>2006-12-14T13:00:13</ogc:Literal>
        </ogc:PropertyIsLessThan>
      </ogc:And>
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
Sébastien Geindre
DPREVI/AERO/DEV
05 61 07 84 93
hi everybody,
Merci !
Geoserver has no timezone handling whatsoever now...
Besides, I never played with multiple timezones myself... in GML there
is in fact the possibility to specify the timezone while specifying
a date and time, but how do you know in which timezone the database
server is handling your data? To make a comparison, you have to
reduce all of the times to a common timezone, no?
Thanks Andrea,
Just a small question bug 'Time Conversion Failed' (http://jira.codehaus.org/browse/GEOT-1331) fixed in 1.5 version also fixed in 1.6 version ?
or 1.6 is a branck which forked before the GEOT-1331ixed release ?
this question because it seems that i have this problem with 1.6 version.
i explain :
in my postGIS database i have
issue_time (timeStamp) : 2006-12-14 12:18:00
when i request via wfs :
    <ogc:Filter>
       <ogc:FeatureId fid="1"/>
    </ogc:Filter>
    </wfs:Query>
i get :
<wims:ice_geom fid="ice_geom.1">
   <wims:issue_time>2006-12-14T11:18:00</wims:issue_time>
it seems that postGIS has +01 time zone.
but a SHOW TIMEZONE gives me Europe/Paris which is +02 UTC
and when i change the database type of issue-time colunm to timestamptz (with tz), the data changed into 2006-12-14 12:18:00+01
And that explain thw wfs response.
it seems to be a postGIS configuration problem...But i ask, we never know...perhaps you met this kind f pb....
