[Geoserver-users] WFS Data Export to SHP from GeoServer Results in Long Char Attributes
Hi all
If I download a shapefile using a link like this: WFS export link
<http://maps.gcc.tas.gov.au:8080/geoserver/GCC_cc/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=GCC_cc%3ABuildings&maxfeatures=50&outputformat=SHAPE-ZIP&gt;
the resulting shapefile has a huge DBF file associated with it. This is due
to white space padding for 255 length char fields.
Is this an issue that only I am having, or is it a GeoServer problem? I can
export the same file using org2ogr on the server, and it results in a
shapefile with char field lengths which are the same as the PostGIS table
backing it.
Alex
View this message in context: http://osgeo-org.1560.n6.nabble.com/WFS-Data-Export-to-SHP-from-GeoServer-Results-in-Long-Char-Attributes-tp5038895.html
Hi Alex,
There was another post a few days ago asking something similar. From that it doesn’t look like GeoServer can currently do this, though it would certainly make sense for the filesize reason.
Jonathan
On 7 March 2013 00:31, Alex Leith <alexgleith@anonymised.com> wrote:
Hi all
<http://maps.gcc.tas.gov.au:8080/geoserver/GCC_cc/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=GCC_cc%3ABuildings&maxfeatures=50&outputformat=SHAPE-ZIP>
backing it.
Alex
Symantec Endpoint Protection 12 positioned as A LEADER in The Forrester
Wave™: Endpoint Security, Q1 2013 and “remains a good choice” in the
endpoint security space. For insight on selecting the right partner to
tackle endpoint security challenges, access the full report.
http://p.sf.net/sfu/symantec-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Thu, Mar 7, 2013 at 11:09 AM, Jonathan Moules <jonathanmoules@anonymised.com…4942…> wrote:
Hi Alex,
Can someone open a request for improvement on jira.codehaus.org?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Done. https://jira.codehaus.org/browse/GEOS-5694 - hopefully that covers it.
Jonathan
Hi Alex,
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Andrea
I’m not a member at jira.codehaus.org, so could someone either join me up or add the feature request for me?
On Thu, Mar 7, 2013 at 10:34 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Mar 7, 2013 at 11:09 AM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Alex,
Ing. Andrea Aime
@geowolf
Technical Lead
Alex Leith
e: alexgleith@anonymised.com.84…
m: 0419189050
On Mon, Mar 11, 2013 at 10:25 PM, Alex Leith <alexgleith@anonymised.com> wrote:
Hi Andrea
I’ve opened a bug report against codehaus for the inability to register:
http://jira.codehaus.org/browse/HAUS-2299
Ing. Andrea Aime
@geowolf
Technical Lead
