[Geoserver-users] WFS Feature count
Hi Users,
Is there a way that will provide a wfs feature count within a bounding box to indicate that the maxFeatures has been reached without using a getfeature request?
For instance:
I’m required to execute a WFS getfeature request with bbox filter.
The WFS Service has a max feature limit of say 10000 polygons.
Can I do a feature count without executing a getfeature request?
I don’t want to perform large requests, then wait until the features are returned only to find polygons missing because of the feature limit.
Thanks
Todd
This e-mail and any files transmitted with it are intended only for the use of the addressee(s). It may contain information that is confidential and privileged, in which case neither is intended to be waived or lost by mistaken delivery to you. If you are not an intended recipient, any use, interference with, disclosure, distribution or copying of this material is unauthorised and prohibited. If you receive this e-mail in error, please notify the sender by return e-mail and delete the message and any attachments from your system. Unless specifically indicated, this e-mail does not constitute formal advice or commitment by the sender or the Western Australian Land Information Authority (Landgate). Information in this message not relating to the official business of Landgate shall be understood as neither given nor endorsed by it. It is your responsibility to check any attachments for viruses and defects before opening or sending them on. Landgate’s liability is limited to re-supplying affected attachments.
WFS 1.1 has resultType hits for this. It is a GetFeature request but
Geoserver will probably just do a count on the database.
Best regards,
Bart
Hi Users,
getfeature request?
For instance:
I'm required to execute a WFS getfeature request with bbox filter.
I don't want to perform large requests, then wait until the features are
Thanks
Todd
attachments.
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World(TM) will have
the opportunity to enter the BlackBerry Developer Challenge. See full
prize
details at:
http://p.sf.net/sfu/Challenge_______________________________________________
Geoserver-users mailing list
