Hi list,
I'm trying to make a simple WFS getFeature request looking at the
WFS_getfeatureBBox in the GeoServer demo request section.
This is my request:
<wfs:GetFeature service="WFS" version="1.0.0" outputFormat="GML2"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd">
<wfs:Query typeName="ras:IDT_AA01G_COMUNI">
<wfs:PropertyName>ras:AA01_NOME</wfs:PropertyName>
<wfs:PropertyName>ras:AA01_COD_PROV_ISTAT</wfs:PropertyName>
<wfs:PropertyName>ras:AA01_COD_REG_ISTAT</wfs:PropertyName>
<ogc:Filter>
<ogc:BBOX>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:coordinates>1448374.66,4513653.33
1448384.66,4513663.33</gml:coordinates>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
But I'm getting this response:
<ServiceExceptionReport version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xsi:schemaLocation="http://www.opengis.net/ogc
http://coreweb2.corenet.it:80/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd">
<ServiceException
locator="org.vfny.geoserver.util.requests.readers.XmlRequestReader">org.xml.sax.SAXException:
Attempted to construct illegal filter: Got to the end state of an
incomplete filter, current state is leftValue
org.xml.sax.SAXException: Attempted to construct illegal filter: Got
to the end state of an incomplete filter, current state is
leftValue</ServiceException>
</ServiceExceptionReport>
What am I doing wrong?
Paolo
Hi Paulo,
Which version of GeoServer are you using? Also it would be handy if we
could have the complete error. There should be a stack trace on your
console or in the log. If you could include it that would be helpful.
Also... this is just a thought but which type of datasource are you
using. In the case of a database are you sure the geometry column is set
up properly.
-Justin
Paolo Moretti wrote:
Hi list,
This is my request:
<ogc:Filter>
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
<ServiceException
Paolo
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list
!DSPAM:4007,47977880141221431913854!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Paolo Moretti ha scritto:
Hi list,
This is my request:
<ogc:Filter>
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
<ServiceException
You're specifying an invalid request, xml wise. The definition of BBOX in filter 1.0 spec (the one used by wfs 1.0) is:
<xsd:complexType name="BBOXType">
<xsd:complexContent>
<xsd:extension base="ogc:SpatialOpsType">
<xsd:sequence>
<xsd:element ref="ogc:PropertyName"/>
<xsd:element ref="gml:Box"/>
</xsd:sequence>
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
so you have to specify both the property name and the box.
Wondering which version of GeoServer you're using thought, trying
against 1.6.0 I got a different error message
Hmmm... you are right Andrea. I also checked filter 1.1 and it is the
same. I seem to remember somethng in the spec about BBOX saying that if
no PropertyName is included then it should be supplemented with "the
default". Perhaps my memory is playing tricks on me again
Hi list,
This is my request:
<ogc:Filter>
<ogc:BBOX>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
<ServiceException
<xsd:sequence>
</xsd:sequence>
</xsd:extension>
</xsd:complexType>
!DSPAM:4007,47984e90132927082231907!
Justin Deoliveira
No tricks, it's just what we have to do with the BBOX kvp
parameter. But it does not apply to xml
Thanks for your help, I was specifying an invalid request.
No problem. Please, don't send me private mails thought.
http://docs.codehaus.org/pages/viewpage.action?pageId=57507867
However. I'm getting a new problem with GeoServer 1.5.4.
This is my new request:
<ogc:PropertyName>ras:AA01_NOME</ogc:PropertyName>
<ogc:PropertyName>ras:AA01_COD_PROV_ISTAT</ogc:PropertyName>
<ogc:PropertyName>ras:AA01_COD_REG_ISTAT</ogc:PropertyName>
<ogc:Filter>
<ogc:BBOX>
<ogc:PropertyName>AA01_GEOMETRIA</ogc:PropertyName>
</gml:Box>
</ogc:BBOX>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
And this is the response:
<wfs:FeatureCollection xmlns="http://www.opengis.net/wfs"
xmlns:ras="http://www.regione.sardegna.it"
xsi:schemaLocation="http://www.regione.sardegna.it
http://coreweb2.corenet.it:80/geoserver/wfs/DescribeFeatureType?typeName=ras:IDT_AA01G_COMUNI
http://coreweb2.corenet.it:80/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd">
<gml:boundedBy>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#3003">
<gml:coordinates xmlns:gml="http://www.opengis.net/gml"
decimal="." cs="," ts=" ">1426638,4500228.5
1469937.38,4524490</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<ras:IDT_AA01G_COMUNI fid="IDT_AA01G_COMUNI.090064">
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<ras:AA01_NOME>SASSARI</ras:AA01_NOME>
<ras:AA01_COD_PROV_ISTAT>090</ras:AA01_COD_PROV_ISTAT>
<ras:AA01_COD_REG_ISTAT>20</ras:AA01_COD_REG_ISTAT>
<ras:AA01_AREA>547384000</ras:AA01_AREA>
<ras:AA01_PERIMETRO>170973.797</ras:AA01_PERIMETRO>
<ras:AA01_GEOMETRIA>
<gml:MultiPolygon
<gml:polygonMember>
<gml:Polygon>
</gml:Polygon>
</gml:polygonMember>
</gml:MultiPolygon>
</ras:AA01_GEOMETRIA>
<ras:AA01_ID_COMUNE>47</ras:AA01_ID_COMUNE>
</ras:IDT_AA01G_COMUNI>
</gml:featureMember>
</wfs:FeatureCollection>
It seems the tag <ogc:PropertyName> it's not working, because I'm
getting all the properties and the GML Geometry.
Strange... hum, in any case 1.5.4 is the last release of GeoServer
1.5.x series, so there is no much point trying to understand what's
wrong. Can you try with 1.6.0-rc3 and see if the problem is still there?
