[Geoserver-users] WFS GetFeature Post Request
Dear community,
I have a received a message from an engineers office on a faulty wfs filter request to get features from our GeoServer (Version 2.4.4):
The Request was:
POST http://www.list.smwa.sachsen.de/baustelleninfo/wfs? HTTP/1.1
Content-Type: text/xml;charset=UTF-8
User-Agent: Iwan WebMapServer (info:http://www.webmapserver.de/) IDUGeolib/6.2.0 Build 145
Connection: Keep-Alive
Content-Length: 889
Host: www.list.smwa.sachsen.de
Authorization: Basic U1BFUlJfU046IVNwM3IxNE4h
<?xml version='1.0' encoding='UTF-8'?>
<wfs:Query typeName=‘services:Strassensperrungen_Aktuell’>
wfs:PropertyNameservices:geom</wfs:PropertyName>
ogc:PropertyNameservices:geom</ogc:PropertyName><gml:Envelope xmlns:gml=‘http://www.opengis.net/gml’ srsName=‘EPSG:31468’>
gml:lowerCorner5674610.89993951 4623372.64610281</gml:lowerCorner>
gml:upperCorner5675455.82080778 4624530.12384099</gml:upperCorner>
</gml:Envelope>
ogc:PropertyNameservices:Verwaltungskennziffer</ogc:PropertyName>
0014627
</wfs:Query>
</wfs:GetFeature>
and the answer:
<ows:ExceptionReport xmlns:ows=“http://www.opengis.net/ows” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/ows http://www.list.smwa.sachsen.de:80/baustelleninfo/schemas/ows/1.0.0/owsExceptionReport.xsd”>
<ows:Exception exceptionCode=“InvalidParameterValue”>
ows:ExceptionTextInvalid request
cvc-pattern-valid: Value ‘services:Strassensperrungen_Aktuell’ is not facet-valid with respect to pattern ‘((\w:)?\w(=\w)?){1,}’ for type ‘TypeNameListType’.
cvc-attribute.3: The value ‘services:Strassensperrungen_Aktuell’ of attribute ‘typeName’ on element ‘wfs:Query’ is not valid with respect to its type, ‘TypeNameListType’.</ows:ExceptionText>ows:ExceptionTextcvc-pattern-valid: Value ‘services:Strassensperrungen_Aktuell’ is not facet-valid with respect to pattern ‘((\w:)?\w(=\w)?){1,}’ for type ‘TypeNameListType’.</ows:ExceptionText>ows:ExceptionTextcvc-attribute.3: The value ‘services:Strassensperrungen_Aktuell’ of attribute ‘typeName’ on element ‘wfs:Query’ is not valid with respect to its type, ‘TypeNameListType’.</ows:ExceptionText></ows:Exception></ows:ExceptionReport>
Does anyone know why this Post-request fails?
Thanks in advance!
Stephan
On Wed, Nov 5, 2014 at 10:26 AM, Klemm, Stephan - LIST <
Because the underscore, _ , is not an allowed character in WFS 1.1 typenames
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Where does the requirement not to accept underscore come from? I have been thinking that the WFS 1.1.0 schema presents QName leads to NCName with a possible prefix
<xsd:complexType name="FeatureTypeType">
<xsd:annotation>
<xsd:documentation>
            An element of this type that describes a feature in an application
            namespace shall have an xml xmlns specifier, e.g.
            xmlns:bo="[http://www.BlueOx.org/BlueOx"](http://www.blueox.org/BlueOx%22);
         </xsd:documentation>
</xsd:annotation>
<xsd:sequence>
<xsd:element name="Name" type="xsd:QName">
And NCName according to this document does allow underscores everywhere:
http://www.datypic.com/sc/xsd/t-xsd_NCName.html
-Jukka Rahkonen-
Andrea Aime wrote:
On Wed, Nov 5, 2014 at 10:26 AM, Klemm, Stephan - LIST <Stephan.Klemm@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Nov 5, 2014 at 1:30 PM, Rahkonen Jukka (Tike) <
jukka.rahkonen@anonymised.com> wrote:
a possible prefix
In the Query typeName is not defined as NCName, but as TypeNameListType:
<xsd:attribute name="typeName" type="wfs:TypeNameListType" use="required">
<xsd:annotation>
<xsd:documentation>
The typeName attribute is a list of one or more feature type names that
indicate which types of feature instances should be included in the reponse
set. Specifying more than one typename indicates that a join operation is
being performed. All the names in the typeName list must be valid types
that belong to this query's feature content as defined by the GML
Application Schema.
</xsd:annotation>
</xsd:attribute>
<xsd:simpleType name="TypeNameListType">
<xsd:restriction base="wfs:Base_TypeNameListType">
<xsd:pattern value="((\w:)?\w(=\w)?){1,}">
<xsd:annotation>
<xsd:documentation>
Example typeName attribute value might be: typeName="ns1:Inwatera_1m=A,
ns2:CoastL_1M=B" In this example, A is an alias for ns1:Inwatera_1m and B
is an alias for ns2:CoastL_1M.
</xsd:annotation>
</xsd:pattern>
</xsd:restriction>
</xsd:simpleType>
The funny thing is that the documentation uses _, but then again the XML
validators do not accept it,
and the moment I removed it, the validation of the document passed.
So, I have to assume that \w does not include "_" as a valid char.
According to some docs I've found on the internet \w is defined as:
"Any character that might appear in a word. A shortcut for
'[#X0000-#x10FFFF]-[\p{P}\p{Z}\p{C}]' (all characters except the set of
"punctuation", "separator", and "other" characters)."
I guess _ might be seen as a separator?
I've also tried to use "ns1:Inwatera_1m=A, ns2:CoastL_1M=B" in a
GetFeature, and I cannot find a way to fix it,
which is not surprising, since WFS 1.1 does not support joining to start
with...
Ing. Andrea Aime
@geowolf
Technical Lead
Hi both,
thanks for your help!
Well, then the engineering office must take up the version 1.0.0! J Nope, we’ll just adjust the layer name and wait…
Best Regards
Stephan
Von: andrea.aime@…84… [mailto:andrea.aime@…84…] Im Auftrag von Andrea Aime
Gesendet: Mittwoch, 5. November 2014 14:12
An: Rahkonen Jukka (Tike)
Cc: Klemm, Stephan - LIST; GeoServer Mailing List List
Betreff: Re: [Geoserver-users] WFS GetFeature Post Request
On Wed, Nov 5, 2014 at 1:30 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@…486…> wrote:
<xsd:attribute name=“typeName” type=“wfs:TypeNameListType” use=“required”>
xsd:annotation
xsd:documentation
The typeName attribute is a list of one or more feature type names that indicate which types of feature instances should be included in the reponse set. Specifying more than one typename indicates that a join operation is being performed. All the names in the typeName list must be valid types that belong to this query’s feature content as defined by the GML Application Schema.
</xsd:annotation>
</xsd:attribute>
<xsd:simpleType name=“TypeNameListType”>
<xsd:restriction base=“wfs:Base_TypeNameListType”>
<xsd:pattern value=“((\w:)?\w(=\w)?){1,}”>
xsd:annotation
xsd:documentation
Example typeName attribute value might be: typeName=“ns1:Inwatera_1m=A, ns2:CoastL_1M=B” In this example, A is an alias for ns1:Inwatera_1m and B is an alias for ns2:CoastL_1M.
</xsd:annotation>
</xsd:pattern>
</xsd:restriction>
</xsd:simpleType>
The funny thing is that the documentation uses _, but then again the XML validators do not accept it,
So, I have to assume that \w does not include “_” as a valid char.
According to some docs I’ve found on the internet \w is defined as:
“Any character that might appear in a word. A shortcut for ‘[#X0000-#x10FFFF]-[\p{P}\p{Z}\p{C}]’ (all characters except the set of “punctuation”, “separator”, and “other” characters).”
I’ve also tried to use “ns1:Inwatera_1m=A, ns2:CoastL_1M=B” in a GetFeature, and I cannot find a way to fix it,
which is not surprising, since WFS 1.1 does not support joining to start with…
Ing. Andrea Aime
@geowolf
Technical Lead
Sorry, coming to this thread a little late after experiencing the same
error...
I know it's only a little book, but Regular Expression Pocket Reference by
Tony Stubblebine <http://shop.oreilly.com/product/9780596004156.do&gt; tells
me that (Class shorthands \w, ...), a word character is often all ASCII
alphanumeric characters plus the underscore, however... can include
additional locale or Unicode alphanumerics. So this definition tells us
that the underscore should be matched by the regex and should work with
strict CITE conformance to WFS 1.1.0.
I'm not sure whether this makes an error like the below a bug in GeoServer
(2.7.0), or a bug with one or more XML validators, but it does seem to be a
bug.
James
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-GetFeature-Post-Request-tp5171303p5206460.html
From this old thread https://sourceforge.net/p/deegree/mailman/deegree-users/?viewmonth=201009&viewday=17 you can read that Markus Schneider from the deegree project and unnamed people from the OGC WFS group considered "that the schema is broken, but it's o.k. to use underscores."
Also http://stackoverflow.com/questions/3367205/is-something-wrong-with-my-regex explains:
a) from XML Schema reference on regexp:
\w - Any character that might appear in a word. A shortcut for '[#X0000-#x10FFFF]-[\p{P}\p{Z}\p{C}]' (all characters except the set of "punctuation", "separator", and "other" characters).
b) underscore character definition in Unicode is 'LOW LINE' (U+005F), category: punctuation, connector [Pc]
Thus underscore seems to be a punctuation mark and punctuation marks are not allowed in \w and therefore underscore breaks the WFS schema.
-Jukka Rahkonen-
________________________________________
error...
bug.
James
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
Geoserver-users mailing list
We are preparing to move to a new server, and at the same time upgrade Geoserver from 2.3.1 to (at least) 2.5.4. The new server is a Centos 7 server and we have got Tomcat 8 and Geoserver working already. But before setting GEOSERVER_DATA_DIR to point to old 2.3.1 data, I'd like to know, what should I do (configuration?).
Oiva Hakala, Natural Resources Institute Finland
On Tue, May 26, 2015 at 11:49 AM, Hakala Oiva (Luke) <oiva.hakala@anonymised.com.>
Just make a backup of the entire content of the data directory, as a newer
GeoServer might modify its contents, besides that, nothing else to do.
If you are doing the upgrade now I'd suggest to move to a 2.6.x though, the
2.5.x series is no longer supported, 2.6.x is in maintenance mode
(only bug fixes) for another 4 months instead, while 2.7.x (current stable)
has 10 months ahead.
Meet us at the INSPIRE Conference in Lisbon 25-29 May 2015! Visit
http://goo.gl/WHKDXT for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
