I started to think that perhaps the XML schema is checked only for POST requests but not for KVP with CQL_FILTER and therefore we have never had problems with underscores in feature type names. Or could it be because we use WFS 1.0.0. in most applications?
-Jukka-
Lähettäjä: andrea.aime@…84… [mailto:andrea.aime@…84…] Puolesta Andrea Aime
Lähetetty: 6. marraskuuta 2014 11:46
Vastaanottaja: Rahkonen Jukka (Tike)
Kopio: Klemm, Stephan - LIST; GeoServer Mailing List List
Aihe: Re: [Geoserver-users] WFS GetFeature Post Request
On Wed, Nov 5, 2014 at 3:32 PM, Rahkonen Jukka (Tike) <jukka.rahkonen@…486…> wrote:
By reading the WFS 1.1.0 standard with whole lot of examples with underscores in the names and also by comparing the schema of DescribeFeatureType which defines the typeName to be xsd:QName this feels like a bug in the standard. And we have loads of WFS layers which have been in production for 6 years and which have underscores in the names. If GeoServer now does not accept those I would call it as depreciation.
Nothing changed. I believe our Stephan enabled scrict CITE compliance in the WFS panel,
and that enables XML schema validation of all incoming requests, which results in this error.
WFS 2.0.0 refers to FES 2.0 http://docs.opengeospatial.org/is/09-026r2/09-026r2.html which makes it clear:
“typeNames parameter
The mandatory typeNames parameter shall be used within an ad hoc query expression to encode the names of one or more correlated resource types to be queried. Individual resource type names shall be encoded as QName (as given in W3C XML Schema Part 2).”
I haven’t tried, but I’m almost sure you won’t see that error if you use WFS 2.0
Now what is unclear is WFS 1.1.0 which says that underscores are NOT OK in query but they are OK for example in DescribeFeatureType
Forget the specification, it’s the XML schema that matters here
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
