here is my request :
http://172.31.172.244:8080/geoserver/wfs?service=WFS&version=1.0.0&request=GetFeature&typename=bluecham:communes&FEATUREID=communes.8
it works when i call it in FireFox.. it returns all informations about my
polygon.
but in my code, i use the same request :
url =
"http://172.31.172.244:8080/geoserver/wfs?service=WFS&version=1.0.0&request=GetFeature&typename=bluecham:communes&FEATUREID=communes.8";
OpenLayers.loadURL(url, '', this, wfsResponse);
function wfsResponse(response) {
alert(response.responseText);
the alert return me a different response, well constructed but with no
data...
firebug give me the same reponse (almost null) when i spy on it...
why the 2 responses are different... i cannot get the feature properly to
highlight it..
any idea ?
thanks for your help
View this message in context: http://www.nabble.com/wfs-getfeature-trouble-tp21431142p21431142.html
floflo ha scritto:
polygon.
url =
data... firebug give me the same reponse (almost null) when i spy on it...
highlight it..
any idea ?
Hum, a couple:
* firefox usually fixes unproperly url-encoded params before sending
the requests, the javascript code does not.
However, this does not seem your specific case
* javascript code can only call back the server where it originated
from, that is, same ip and same port. So if your javascript is
being served by apache you have to proxy geoserver so that it
looks like it is sitting on the same port.
Alternatively, in the GeoServer data directory there is a folder
named "www" where you can put static files that will be published
at http://host:port/geoserver/www
Andrea Aime
OpenGeo - http://opengeo.org
Ok, it's because the command :
adds a '?' a the end of the query... because the paremeter "paremeter" is
set to ''
so be sure you fixed parameters to null if you already set parameters in
your url..
thks
floflo wrote:
polygon.
url =
data...
highlight it..
any idea ?
View this message in context: http://www.nabble.com/wfs-getfeature-trouble-tp21431142p21472477.html
