I'm still trying out stuff in Geoserver and tried to use the demo page to do a wfs insert. Here's my setup: PostGIS with a table named gtest, with columns city (text) and coor (Point Geometry). I added gtest as a featuretype, and tried to submit the following at the wfs demo page:
<wfs:Transaction service="WFS" version="1.0.0"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:topp="http://www.openplans.org/topp"
xmlns:gml="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd http://www.openplans.org/topp http://localhost:8080/geoserver/wfs/DescribeFeatureType?typename=topp:gtest">
<wfs:Insert>
<topp:gtest>
<topp:coor>
<gml:Point srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:coordinates decimal="." cs="," ts=" ">
23,12
</gml:coordinates>
</gml:Point>
</topp:coor>
<topp:city>test</topp:city>
</topp:gtest>
</wfs:Insert>
</wfs:Transaction>
This is what I got back:
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://localhost:8080/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd">
<ServiceException locator="null gtest 1">
topp:gtest is read-only </ServiceException>
</ServiceExceptionReport>
What did I do wrong? In the datastore config I put in the username and password that created my database, so it should have write access right?
In the future, where can I look to debug this sort of errors?
Thanks in advance.
Doris
dlamoris@anonymised.com ha scritto:
<wfs:Insert>
<topp:gtest>
<topp:coor>
23,12
</gml:coordinates>
</gml:Point>
</topp:coor>
</topp:gtest>
</wfs:Insert>
</wfs:Transaction>
Thanks in advance.
My guess is that the gttest does not have a primary key. As such, it cannot be written correctly because the output of a transaction
must state then new ID of the created feature.
Add a column of type "serial", make it primary key, and you should
be fine.
Yet...hmmm... we could state the nature of the issue a little better than that...
