Using Geoserver 1.6.2, I have a problem with an entity (from a postgis table composed of approx 2000 points) when I request a WMS : not all the points are represented on the map (only 100 maybe) whereas the wfs result is correct. Is there a limitation to unlock in order to get the right result ?
Laurent
