[Geoserver-users] wfs limits ?
Using Geoserver 1.6.2, I have a problem with an entity (from a postgis table composed of approx 2000 points) when I request a WMS : not all the points are represented on the map (only 100 maybe) whereas the wfs result is correct. Is there a limitation to unlock in order to get the right result ?
Laurent
Hi Laurent,
A couple of question:
1. do you have any style on the layer which may be placing a filter on the layer, perhaps based on scale?
2. Are the points very close together? I am not sure how the render decimation works... but perhaps it could be coming into play here. Andrea can better comment on this one.
-Justin
laurent pierrre wrote:
Laurent
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
!DSPAM:4007,47f3954a30942092453641!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Justin Deoliveira ha scritto:
Hi Laurent,
No, decimation should not kill separate points. I'm wondering, you
sure your wms requests are using the full bbox of your data?
Hi Laurent,
Yes that's it . I made a style with UDIG to give a different color to each categorie but I might have made a mistake and lost some sets of data. With a simpler style all the points are here.
Thanks a lot I wouldn' have found it alone.
Laurent
