Not directly as far as I know, but by sending GetFeature without filters and with resulttype=hits it should be possible to do a good guess.
-Jukka Rahkonen-
Jonathan Moules wrote:
Hi List,
Relatively simple question, is it possible to a client to discover what the maximum number of results are that the GeoServer will return to a WFS request if the user has set “Maximum number of features”?
It doesn’t seem to be specified in the GetCapabilities explicitly. Closest I can see is the WFS 2.0 "ows:Constraint name=“CountDefault”
Does 1.0 have any way to find it out?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
