Hi Jonathan,
This is another WFS but like this it should work
Client side maxfeatures=10, numberOfFeatures=10
http://hip.latuviitta.org/cgi-bin/tinyows?service=wfs&version=1.1.0&maxfeatures=10&request=getfeature&typename=lv:mtk_tos_viiva&resulttype=hits
No client side maxfeatures, numberOfFeatures=100000, probably the server side limit
-Jukka Rahkonen-
Jonathan Moules
Hi Jukka,
Ok. It just seems like the sort of thing that would be very important for the client to know so it can tell the user “Server returned 1000 features but the server will only ever return 1000 features at a time so this may not be the entire dataset”.
Testing your suggestion, whenever I do that I always get back the exact same:
<wfs:FeatureCollection xmlns:OS_Rasters=“http://www.warwickshire.gov.uk/os_rasters” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:Secure_Community=“http://www.warwickshire.gov.uk/Secure_Community” xmlns:OS_Vector=“http://www.warwickshire.gov.uk/os_vector” xmlns:wfs=“http://www.opengis.net/wfs” xmlns:ows=“http://www.opengis.net/ows” xmlns:xlink=“http://www.w3.org/1999/xlink” xmlns:Misc_Rasters=“http://www.warwickshire.gov.uk/misc_rasters” xmlns:gml=“http://www.opengis.net/gml” xmlns:Public_Data_DB=“http://www.warwickshire.gov.uk/public_data_db” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” numberOfFeatures=“0” timeStamp=“2013-11-08T14:55:55.783Z” xsi:schemaLocation=“http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd”/>
Note it’s claimed 0 features. Despite the fact the request does return 7500 features (maximum). A bug? I’ve not used that before.
Jonathan
On 8 November 2013 14:34, Rahkonen Jukka <jukka.rahkonen@anonymised.com6…> wrote:
Not directly as far as I know, but by sending GetFeature without filters and with resulttype=hits it should be possible to do a good guess.
-Jukka Rahkonen-
Jonathan Moules wrote:
Hi List,
Relatively simple question, is it possible to a client to discover what the maximum number of results are that the GeoServer will return to a WFS request if the user has set “Maximum number of features”?
It doesn’t seem to be specified in the GetCapabilities explicitly. Closest I can see is the WFS 2.0 "ows:Constraint name=“CountDefault”
Does 1.0 have any way to find it out?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
