[Geoserver-users] WFS-Post Request via Java, no success?
Hello folks,
I'm trying to do a wfs post request via java to the geoserver. I just want to do a simple getFeature Requst. For testing I took the xml body from the demo page. (WFS_getFeature_1.0.xml). Error and Java Code following...
Error response:
"<?xml version="1.0" encoding="UTF-8"?>
<ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:ows="http://www.opengis.net/ows&quot;&gt;
<ows:Exception exceptionCode="MissingParameterValue" locator="request">
<ows:ExceptionText>Could not determine geoserver request
   from http request org.apache.catalina.connector.RequestFacade@anonymised.com</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>"
Here's my Java Code:
public void postTest() throws Exception{
     URL url = new URL ("http://localhost:8080/geoserver/wfs&quot;\);
     String xml ="<wfs:GetFeature service='WFS' version='1.0.0' outputFormat='GML2' xmlns:topp='http://www.openplans.org/topp’ xmlns:wfs='http://www.opengis.net/wfs’ xmlns:ogc='http://www.opengis.net/ogc’ xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance’ xsi:schemaLocation='http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd’><wfs:Query typeName='topp:states'><ogc:Filter><ogc:FeatureId fid='states.3'/></ogc:Filter></wfs:Query></wfs:GetFeature>";
     String tmp = null;
           // Get connection
     URLConnection urlConn = url.openConnection();
     urlConn.setDoInput (true);
     urlConn.setDoOutput (true);
     urlConn.setUseCaches (false);
     urlConn.setRequestProperty("Content-Type", "application/x-www-form-urlencoded");
           // Write output
     DataOutputStream printout = new DataOutputStream (urlConn.getOutputStream ());
     String data = URLEncoder.encode("url", "UTF-8") + "=" + URLEncoder.encode("http://localhost:8080/geoserver/wfs&quot;, "UTF-8");
            data += "&" + URLEncoder.encode("body", "UTF-8") + "=" + URLEncoder.encode(xml, "UTF-8");
            data += "&" + URLEncoder.encode("username", "UTF-8") + "=" + URLEncoder.encode("admin", "UTF-8");
            data += "&" + URLEncoder.encode("password", "UTF-8") + "=" + URLEncoder.encode("geoserver", "UTF-8");
     printout.writeBytes (data);
     printout.flush ();
     printout.close ();
           // Get response
     DataInputStream input = new DataInputStream (urlConn.getInputStream ());
           while (null != ((tmp = input.readLine())))
         System.out.println (tmp);
     input.close();
The console says:
09 Jun 14:07:48 INFO [geoserver.filters] - 127.0.0.1 "POST /geoserver/wfs" took 221ms
09 Jun 14:08:16 INFO [geoserver.filters] - 127.0.0.1 "POST /geoserver/wfs" "Java/1.6.0_03" ""
09 Jun 14:08:16 WARN [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not determine geoserver request from http request org
What's the problem? Maybe someone of you can help me.
Sebastian
Hi Sebastian,
The problem here is the use of the content type "x-www-form...". When GeoServer sees this content type it essentially treats the request as a GET pulling the kvp's from the body rather than the header.
So in this case it sees three key value pairs: body, username + password. The problem is that "body" is not recognized to be special... so it wont parse it as xml or anything.
Anyways, to get this to work i believe you will have to change the content type to "text/xml" or "application/xml". Now to send the username and password you need to use the "Authorization" header in the request. Something like this:
HttpURLConnection conn = ...;
String username = "...";
String password = "...";
byte b = Base64.encodeBase64(username + ":" + password);
String authHeader = "Basic " + new String(b);
conn.setRequestProperty("Authorization", authHeader);
Hope that helps,
-Justin
Sebastian wrote:
Hello folks,
Error response:
</ows:Exception>
     String tmp = null;
           // Get connection
           // Write output
     printout.flush ();
     printout.close ();
           // Get response
     input.close();
The console says:
Sebastian
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
Geoserver-users mailing list
!DSPAM:4007,484dac34232693668746562!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Sebastian ha scritto:
Hello folks,
Error response:
</ows:Exception>
     String tmp = null;
           // Get connection
           // Write output
     printout.flush ();
     printout.close ();
           // Get response
     input.close();
The console says:
Hum, I'd say wrong MIME type:
http://geoserver.org/display/GEOSDOC/My+WFS+POST+does+not+work.
Hello folks,
Error response:
</ows:Exception>
     String tmp = null;
           // Get connection
           // Write output
     printout.flush ();
     printout.close ();
           // Get response
     input.close();
The console says:
I changed the mime-type to application/xml but now I get a
"NoApplicableCode" Exception:
<ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>org.xmlpull.v1.XmlPullParserException:
      only whitespace content allowed before start tag and
      not u (position: START_DOCUMENT seen u... @1:1) only
      whitespace content allowed before start tag and not u
      (position: START_DOCUMENT seen u... @1:1) </ows:ExceptionText>
  </ows:Exception>
I think the xml body isn't recognized, what attribute name do I need?
Regards and Thanks,
Sebastian
  </ows:Exception>
Did you remove the url encoding of the xml? It looks like it is still being sent encoded.
Regards and Thanks,
Sebastian
!DSPAM:4007,48501b40201447180515871!
Justin Deoliveira
On Thu, 12 Jun 2008 08:35:20 -0700, Justin Deoliveira
  </ows:Exception>
being sent encoded.
Regards and Thanks,
Sebastian
Justin Deoliveira
Hmm... thats my code now:
      String xml = "<wfs:Transaction .... </wfs:Transaction>";
      String tmp = null;
      // Get connection
      URLConnection conn = url.openConnection();
      conn.setDoInput (true);
      conn.setDoOutput (true);
      conn.setUseCaches (false);
      conn.setRequestProperty("Content-Type", "application/xml");
      // Write output
      DataOutputStream printout = new DataOutputStream (conn.getOutputStream
      String data = "username=admin&password=geoserver&body="+xml;
      printout.flush ();
      printout.close ();
      // Get response
      DataInputStream input = new DataInputStream (conn.getInputStream ());
      input.close();
and still:
  </ows:Exception>
My xml is ok, I checked it with the probe request site.
Sebastian
Ok, so still a couple of things wrong:
1. The body of the request (ie data variable) must only be the xml, it cannot be key value pairs body, username, and password. So change:
to
String data = xml;
2. GeoServer will not recognize username and password in this way. In my first reply I described how to do authentication in a POST, I provided a code example as well:
-Justin
  </ows:Exception>
being sent encoded.
Regards and Thanks,
Sebastian
Justin Deoliveira
      String tmp = null;
            // Get connection
                  // Write output
      printout.flush ();
      printout.close ();
            // Get response
      input.close();
and still:
  </ows:Exception>
Sebastian
!DSPAM:4007,4852655b279501439371379!
Justin Deoliveira
Thank you!
I had a problem with the base64 encoding, so I just left the encoding away and wrote:
conn.setRequestProperty("Authorization","admin:geoserver");
Now it works :slight_smile:
Thanks again and regards,
Sebastian
to
String data = xml;
-Justin
  </ows:Exception>
being sent encoded.
Regards and Thanks,
Sebastian
Justin Deoliveira
        String tmp = null;
                // Get connection
                        // Write output
        printout.flush ();
        printout.close ();
                // Get response
        input.close();
and still:
  </ows:Exception>
Sebastian
