WFS does actually support that somehow. The query needs just to contain maxFeatures=1 with sortBy ascending/descending. This query returns a town with highest population in 1999 (Helsinki, 515490). You can shorten the response by including also the &propertyname parameter.
This one returns a village with lowest population value (0, means missing data in this case)
I wouldn’t trust that results from an unknown WFS server is right, though. I guess that sorting with different backends ant together with filters is generally very little tested. I am remembering that it worked OK for me with Geoserver and PostGIS once I was playing with this sometimes.
Corresponding Geoserver document page is http://docs.geoserver.org/stable/en/user/services/wfs/reference.html
Results comes from TinyOWS at the moment because my super cheap virtual server does not have enough memory for running Geoserver, sorry for that.
-Jukka Rahkonen-
Martin Davis wrote:
WFS doesn’t support aggregation in queries, only filtering. (In other words, it’s not functionally compatible with SQL).
However, you can do this by using a WPS process. Have a look at the gs:Aggregate process.
On Thu, Dec 13, 2012 at 2:02 AM, zeliofern <zelio.fern@anonymised.com> wrote:
Hi Guys
i have gone through the documentation and it is said that ogc:max and
ogc:min function is just used to get max between provided numbers. also on
ogc and arcgis website it is said to use SortBy in WFS query filter.
i have 2 question :
- does geoserver have support to use sortby in WFS filter query?
2)my requirement is to find the lowest and the highest value in a attribute
of layer published in geoserver
is there any WFS query function to do that?
View this message in context: http://osgeo-org.1560.n6.nabble.com/WFS-query-to-find-lowest-and-highest-value-of-a-attribute-in-a-layer-tp5022702.html
Master Visual Studio, SharePoint, SQL, ASP.NET, C# 2012, HTML5, CSS,
MVC, Windows 8 Apps, JavaScript and much more. Keep your skills current
with LearnDevNow - 3,200 step-by-step video tutorials by Microsoft
MVPs and experts. ON SALE this month only – learn more at:
http://p.sf.net/sfu/learnmore_122712
Geoserver-users mailing list
Martin Davis
OpenGeo - http://opengeo.org
