my layer is working fine when I preview it as a WMS (OpenLayers ) layer ut giving the following error when I try to preview it as WFS. I checked the bounds setting in layer, it looks fine. what might be the problem?
java.lang.ArrayIndexOutOfBoundsException
Is it possible to share the url from browser and exception call stack if any?
-Prem
On Thu, 5 Aug 2021 at 10:18 AM, krishna lodha <krishnaglodha@anonymised.com> wrote:
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Unfortunately sharing URL won’t be possible but results looks like this
Thank you,
Krishna G. Lodha
http://krishnaglodha.com
On 5 Aug 2021, 11:30 AM +0530, Prem Kumar <prem.netgis@anonymised.com>, wrote:
-Prem
> > > Hi,
> > > <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> > > <ServiceException> java.lang.ArrayIndexOutOfBoundsException </ServiceException>
> > > </ServiceExceptionReport>
> > _______________________________________________
> > - Earning your support instead of buying it, but Ian Turton: Earning Your Support Instead of Buying it
> > - The GeoServer user list posting guidelines: User group posting guidelines
> > If you want to request a feature or an improvement, also see this: Successfully requesting and integrating new features and improvements in GeoServer · geoserver/geoserver Wiki · GitHub
> > Geoserver-users@lists.sourceforge.net
> > geoserver-users List Signup and Options
