Yeah I’m able to generate was response for all layers except this
Thank you,
Krishna G. Lodha
http://krishnaglodha.com
On 5 Aug 2021, 7:33 PM +0530, Rahkonen Jukka (MML) <jukka.rahkonen@anonymised.com..>, wrote:
Does the WFS output option of the layer preview utility work with other vector layers, for example the demo layer topp:states?
-Jukka Rahkonen-
Lähettäjä: Krishnaglodha <krishnaglodha@anonymised.com>
Lähetetty: torstai 5. elokuuta 2021 10.27
Vastaanottaja: Prem Kumar <prem.netgis@anonymised.com>
Kopio: Michael Steigemann via Geoserver-users <Geoserver-users@anonymised.comceforge.net>
Aihe: Re: [Geoserver-users] Fwd: [WFS request error] java.lang.ArrayIndexOutOfBoundsException errorHi,
Unfortunately sharing URL won’t be possible but results looks like this<image001.png>
<image002.png>Thank you,
Krishna G. Lodha
On 5 Aug 2021, 11:30 AM +0530, Prem Kumar <prem.netgis@anonymised.com>, wrote:> quote_type
> Hi,
> Is it possible to share the url from browser and exception call stack if any?
> -Prem
> On Thu, 5 Aug 2021 at 10:18 AM, krishna lodha <krishnaglodha@anonymised.com> wrote:
> > quote_type
> > Hi,
> > my layer is working fine when I preview it as a WMS (OpenLayers ) layer ut giving the following error when I try to preview it as WFS. I checked the bounds setting in layer, it looks fine. what might be the problem?
> > <ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> > <ServiceException> java.lang.ArrayIndexOutOfBoundsException </ServiceException>
> > </ServiceExceptionReport>
> > _______________________________________________
> > Geoserver-users mailing list
> > Please make sure you read the following two resources before posting to this list:
> > - Earning your support instead of buying it, but Ian Turton: Earning Your Support Instead of Buying it
> > - The GeoServer user list posting guidelines: User group posting guidelines
> > If you want to request a feature or an improvement, also see this: Successfully requesting and integrating new features and improvements in GeoServer · geoserver/geoserver Wiki · GitHub
> > Geoserver-users@lists.sourceforge.net
> > geoserver-users List Signup and Options
