[Geoserver-users] WFS response not containing columns with null
Hello,
Is it possible to configure Geoserver to output all fields in the WFS response even though they don’t have any value (null)?
What does the standards say about that?
Albin
Lundmark Albin ha scritto:
Hello,
Is it possible to configure Geoserver to output all fields in the WFS response even though they don't have any value (null)?
In case of nullable columns, we generate a schema stating minOccurs=0, so it's ok not to output the element at all.
A compliant parser should be able to handle that case as well.
Hello,
I made a test shapefile in order to see how a real GIS client (OpenJUMP WFS-plugin) works in this sitution. It seemed to have no problem. Even if request lead to response with just nulls in some attribute field, the field was still parsed into the OpenJUMP map layer schema.
What did not work quite right was creating a new Geoserver DataStore from shapefile which had an attribute field with only null values. In this case the Feature Type Editor does not list that shapefile field at all and thus it cannot be included into WFS. If I wrote even one single value to any cell of this field it did get listed by Feature Type Editor. I am playing with Geoserver 1.6.4.
-Jukka Rahkonen-
Rahkonen Jukka ha scritto:
Hello,
minOccurs=0, so it's ok not to output the element at all. A
layer schema.
Interesting. Can you open a jira issue about this, and attach such
sample shapefile? I would like to figure out why the column was not
recognized.
Andrae
recognized.
Created http://jira.codehaus.org/browse/GEOS-2207 with a minimal shapefile as an attachment.
-Jukka-
The schema would permit both omitting the element or outputting the element with empty value i.e null.
I think that controlling this behaviour could be useful, like for instance when the consumer doesn’t have access to the schema (even though that is bad).
Would it be a welcome addition/contribution?
/Björn
Hello,
so it’s ok not to output the element at all.
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
I think that controlling this behaviour could be useful, like for instance when the consumer doesn't have access to the schema (even though that is bad).
Well, yeah, it could be. I'm just wondering about where that can be
used. I mean, in order to decide which flavour you want, you need
to know that all your users have a broken client that does
not handle the missing attributes, and yet no one with a client
broken the other way (one that does not handle empty ones <element/>).
Seems to me you need to be in control of both the server and the
users, and you cannot fix the client software in the first place.
A little odd?
The spec says to omit the element. There was some conversation about this during the cite compliance phase of the spec, and the alternative was to use xs:nil elements for attributes with null values but still mandatory. But the spec writers chose the former.
-Justin
Lundmark Albin wrote:
Hello,
Albin
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Justin Deoliveira
Software Engineer, OpenGeo
http://opengeo.org
That settles it then I guess, thank you for clearing it up!
/Björn
-Justin
Hello,
Albin
Justin Deoliveira
http://opengeo.org
