[Geoserver-users] Wfs serving real arcs instead of stroken arcs
Hi list,
In my data I have an arc geometry. From that data I make a wfs .
When I add the original data and the wfs data in the same map, there is a difference.
The original data is a real arc, the wfs data is a stroked.
Question:
Is it possible to serve a wfs with real arcs instead of stroked arcs?
If it is possible to do so, how can I achieve such a thing?
Or is the wfs-consumer / client responsible for this behaviour?
Thanks
Jan Willem
Adviseur GIS
I'm not sure I'm following you. Perhaps you can explain your specific
scenario in a bit more detail?
Can you say exactly what the source format is (i.e. what are you loading to
the geoserver store)?
Can you say what format you are requesting the WFS service to provide the
feature(s) in?
Can you be a bit more specific in explaining what you mean by "real" and
"stroked"?
By "stroked" do you mean the curve it made up of straight lines?
Brad
I have never tried but there should be support for curves if you use PostGIS http://www.geo-solutions.it/blog/postgis-curves-in-geoserver/
-Jukka Rahkonen-
Lähettäjä: Brad Hards
Lähetetty: ‎29.‎7.‎2016 9:56
Vastaanottaja: ‘Jan Willem van der Lichte’; geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] Wfs serving real arcs instead of stroken arcs
I’m not sure I’m following you. Perhaps you can explain your specific
feature(s) in?
Can you be a bit more specific in explaining what you mean by “real” and
“stroked”?
By “stroked” do you mean the curve it made up of straight lines?
Brad
Geoserver-users mailing list
On Fri, Jul 29, 2016 at 9:14 AM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
There are a few conditions:
   1. A recent version of GeoServer that can handle curves (2.8.x onwards
   should be good I believe, but I did not check)
   2. A data source that can do curves, Oracle or PostGIS
   3. A output format that can encode curves, which means GML 3 or GML 3.2
   exclusively at the moment (no GML2, no JSON, no shapefiles)
   4. No reprojection involved in the request
Point 4 could eventually be lifted, and support for more data sources could
be implemented, pending resourcing/funding
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi
Based on your suggestions, I decided to download a complete new stack 4.8 from Boundless. And is seems to work in combination with Qgis 2.16.
So it can be done.
Thanks a lot for the quick response
Jan Willem
> Hi,
Ing. Andrea Aime
@geowolf
Technical Lead
