briefly looked in the code, it is expecting a esri.properties file to be found in $GEOSERVER_DATA_DIR/user_projections,
the file needs to contain a map from the EPSG codes to the ESRI wkt representation of the same, something like:
2000=PROJCS[“Anguilla_1957_British_West_Indies_Grid”,GEOGCS[“GCS_Anguilla_1957”,DATUM[“D_Anguilla_1957”,SPHEROID[“Clarke_1880_RGS”,6378249.145,293.465]],PRIMEM[“Greenwich”,0.0],UNIT[“Degree”,0.0174532925199433]],PROJECTION[“Transverse_Mercator”],PARAMETER[“False_Easting”,400000.0],PARAMETER[“False_Northing”,0.0],PARAMETER[“Central_Meridian”,-62.0],PARAMETER[“Scale_Factor”,0.9995],PARAMETER[“Latitude_Of_Origin”,0.0],UNIT[“Meter”,1.0]]
2001=PROJCS[“Antigua_1943_British_West_Indies_Grid”,GEOGCS[“GCS_Antigua_1943”,DATUM[“D_Antigua_1943”,SPHEROID[“Clarke_1880_RGS”,6378249.145,293.465]],PRIMEM[“Greenwich”,0.0],UNIT[“Degree”,0.0174532925199433]],PROJECTION[“Transverse_Mercator”],PARAMETER[“False_Easting”,400000.0],PARAMETER[“False_Northing”,0.0],PARAMETER[“Central_Meridian”,-62.0],PARAMETER[“Scale_Factor”,0.9995],PARAMETER[“Latitude_Of_Origin”,0.0],UNIT[“Meter”,1.0]]
On Thu, Oct 2, 2014 at 10:21 AM, HerrFlick <tomas.mattern@anonymised.com> wrote:
maybe this is a stupid question, but what should I do to enable this
checkbox in WFS Service settings?
<http://osgeo-org.1560.x6.nabble.com/file/n5165430/geoserver_WFS.png>
Thanks
Tomas
View this message in context: http://osgeo-org.1560.x6.nabble.com/WFS-SHAPE-ZIP-output-format-checkbox-disabled-tp5165430.html
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
