On Wed, Sep 2, 2015 at 8:52 AM, xmiquel <xmiquel@anonymised.com> wrote:
I am working with 3-dimension feature stored in an Oracle database.
When i retrieve the features in a standard wfs query (gml 3.1), the
response gives me the 3 dimensions of the point.
<gml:Point srsDimension="3"
srsName="http://www.opengis.net/gml/srs/epsg.xml#25831
"><gml:pos>459217.116781156
4670969.51204205 0</gml:pos>
</gml:Point>
However, when I try to do a insert or update with WFS-T request in the demo
console (sent with same format I had recieved), I get an Oracle exception
(Layer Dimensionality does not match geometry dimensions)
Cheking the geoserver log I've seen that Geoserver puts a 2 dimension
geometry in the Oralce Insert Query.
Am I doing anything wrong?
Maybe not... GeoServer did not use to support 3d ordinates at all, the
support was added
bit by bit over the last years on different store and on the reading side,
but I don't remember specific WFS-T work, and I don't see any integration
test
covering this use case, so I believe you're looking at a missing feature
there
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
