[Geoserver-users] WFS-T and Oracle Views
Earlier, GeoServer did not support wfs-t on top of Oracle views. Does anyone know if this is still the case or if this has been added as a feature. I have tried to do use WFS-T with a view and have not been successful thus far.
Thanks
Robert
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
Hi Robert,
in general, they should be usable. You could have some issues with metadata recognition by Geoserver on those views, mainly the type of Geometry and primary key will not be set correctly. If you need them to work with WFS-T you will probably need to create and populate correcly the geotools metadata tables for primary keys as explained here: http://docs.geoserver.org/latest/en/user/data/database/primarykey.html
You could also need to create and fill the geotools specific geometry metadata table, explained here: http://docs.geoserver.org/latest/en/user/data/database/oracle.html#using-the-geometry-metadata-table
Mauro Bartolomeoli
2014-09-15 22:24 GMT+02:00 Price, Robert C. <RCPRICE@anonymised.com1420…>:
Thanks
Robert
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Thanks everyone. I was able to get this up and running.
2014-09-15 22:24 GMT+02:00 Price, Robert C. <RCPRICE@anonymised.com…>:
Thanks
Robert
Want excitement?
