Dear geoserver developers,
I am using geoserver 1.4 (windows installer) and apache 2.0.58. Now I want to do a WFS-T insert request. The data of the WFS lie in a oracle spatial database.
Every time I do my insert request I get the following error message:
org.geotools.data.DataSourceException: SQL Exception writing geometry columnORA-29875: Routine ODCIINDEXINSERT is not executed successfully
ORA-13365: Layer-SRID does not correspond to the Geometry-SRID
ORA-06512: in "MDSYS.SDO_INDEX_METHOD_9I", line 210
ORA-06512: in line 1
So I droped the spatial index for the relevant featuretype in my oracle spatial database and tried to insert the data again. Everything went fine; the data were inserted. Only the entry for SRID in the SDO_SRID array in the GEOM column was 'wrong". The value geoserver fills in is 'NULL'. But it should be '82032' as it was defined in the ALL_SDO_GEOM_METADATA.
Hence I know why geoserver brings up the error message (when having a spatial index) saying: "ODCIINDEXINSERT is not executed successfully, Layer-SRID does not correspond to the Geometry-SRID" because the Layer-SRID is "82032" and geoserver tries to insert SRID-value "NULL" for the GEOMETRY-SRID of the new inserted feature instance and so the insert request fails.
The next thing I tried was to set the SRID for all the existing feature instances to NULL. Likewise I set the SRID in the USER_SDO_GEOM_METADATA to NULL. After that I created a new spatial index (R-Tree). Then I tried to do a WFS-T insert request again. And it works (now with a spatial index).
So the "only" problem seems to be that geoserver does not look what SRID my feature type table is in or rather does not fill in that SRID but inserts "NULL".
So I want to ask you (dear developers) if you could solve this problem? Do you think I am right and inserting data via WFS-T in oracle spatial doesn't work propberly because of the wrong SRID insert geoserver does? Or perhaps you can tell me which file of the geoserver source code is responsible for the SRID selection?
Thank you so much for your help and your technical expertise.
regards
Daniel
Echte DSL-Flatrate dauerhaft für 0,- Euro*. Nur noch kurze Zeit!
"Feel free" mit GMX DSL: http://www.gmx.net/de/go/dsl
Hello Daniel,
Thank you for the information about how it is possible to insert data to Oracle 9i spatial through Geoserver WFS-T. I will insert "null" as my Oracle SRID, in my case it does not matter too much because Oracle has wrong parameters for the Finnish-KKJ coordinate system so reprojection etc. gives wrong results anyway.
Oracle 9 may remain problematic because of the different SRID coding but let's hope that this problem could be solved with Oracle 10g supporting EPSG codes as simply as adding EPSG-SRID to the SQL that Geoserver is sending to Oracle. Is there anybody out there who could make a try with this?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: geoserver-users-bounces@lists.sourceforge.net
[mailto:geoserver-users-bounces@lists.sourceforge.net]
Puolesta Daniel Goetz
Lähetetty: 31. elokuuta 2006 12:28
Vastaanottaja: geoserver-users@lists.sourceforge.net;
geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-users] WFS-T and oracle
the SRID selection?
regards
Daniel
Using Tomcat but need to do more? Need to support web
services, security?
Get stuff done quickly with pre-integrated technology to make
your job easier Download IBM WebSphere Application Server
v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&
dat=121642
Geoserver-users mailing list
