Hello to all,
please does anybody knoww if it is possible to enable wfs-t function only for a dataset and not for the entire server (all datasets) ?
Thanks in Advance
G. Tsolakis, http://www.mpe.gr
On Wed, May 13, 2009 at 7:01 PM, <geoserver-users-request@lists.sourceforge.net> wrote:
Send Geoserver-users mailing list submissions to
geoserver-users@lists.sourceforge.netTo subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
geoserver-users-request@lists.sourceforge.netYou can reach the person managing the list at
geoserver-users-owner@lists.sourceforge.netWhen replying, please edit your Subject line so it is more specific
than “Re: Contents of Geoserver-users digest…”Today’s Topics:
- Problems with GeoServer 1.7.4 and MySql (2StepForward)
- Custom GTRender (Valentin Erastov)
- Re: Custom GTRender (Andrea Aime)
- Re: gwc re generation (Joshua M. Thompson)
- Re: Problems with GeoServer 1.7.4 and MySql (2StepForward)
- Re: new shapefile datastore how do I connect to network drive
data? (John Mitchell)- Re: Custom GTRender (Valentin Yerastov)
- Custom GTRender (Valentin Yerastov)
- URL CoverageStore ArcSDE 9.2 (Geos 1.7.4)
(Velarde Gutierrez, Victor)
Message: 1
Date: Wed, 13 May 2009 06:21:20 -0700 (PDT)
From: 2StepForward <kwegezeder@anonymised.com…157…>
Subject: [Geoserver-users] Problems with GeoServer 1.7.4 and MySql
Message-ID: <23521637.post@anonymised.com.381…>
Content-Type: text/plain; charset=us-asciiHello,
I have installed the new GeoServer 1.7.4 and MySql DataStore Plugin.
Now my currently used Mysql tables have no geometry column in the
FeatureEditor.The Tables are created with thees statement:
CREATE TABLE IF NOT EXISTS
POLYGONS
ID
int(11) NOT NULL auto_increment,
NAME
varchar(255) default NULL,
THE_GEOM
polygon NOT NULL,
PRIMARY KEY (ID
) ENGINE=MyISAM DEFAULT CHARSET=utf8 AUTO_INCREMENT=1 ;The field Name was shown in FeatureEditor, ID is primary and not listed, but
the THE_GEOM field is missed.
I have took the new geoserver-1.7.4-mysql-plugin installed end configured.
The connection is done, only the geometry column is missed.Has anybody the same problem or a solution for that problem.
Thx 2StepForward
View this message in context: http://www.nabble.com/Problems-with-GeoServer-1.7.4-and-MySql-tp23521637p23521637.html
Message: 2
Date: Wed, 13 May 2009 22:42:15 +0800
Subject: [Geoserver-users] Custom GTRender
Message-ID:
<be23fa2a0905130742l5b31f723t434a26c12ee099d7@anonymised.com>
Content-Type: text/plain; charset=ISO-8859-1Hello,
Can I configure Geoserver to use custom GTRender implementation class?
Message: 3
Date: Wed, 13 May 2009 16:46:09 +0200
Subject: Re: [Geoserver-users] Custom GTRender
To: Valentin Erastov <xibyte@anonymised.com>
Message-ID: <4A0ADD31.4070001@anonymised.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowedValentin Erastov ha scritto:
Hello,
Nope, you cannot. But the modifications needed should not be that
many, provided your renderer can really do whatever the streaming
renderer does.
Can you share more information about your custom rendering code?Cheers
Andrea–
Andrea Aime
OpenGeo - http://opengeo.org
Message: 4
Date: Wed, 13 May 2009 10:55:58 -0400
From: “Joshua M. Thompson” <joshua.thompson@anonymised.com>
Subject: Re: [Geoserver-users] gwc re generation
Message-ID:
<3833332e0905130755w30205927u59249ef7724d1db9@anonymised.com>
Content-Type: text/plain; charset=ISO-8859-1On Wed, May 13, 2009 at 6:18 AM, Arne Kepp <ak@anonymised.com> wrote:
if you have a chance, could you please try replacing geowebcache*.jar in
WEB-INF/lib ?with this one ? (Be sure to move the old copy out of lib)http://repo.opengeo.org/org/opengeo/geowebcache/1.1-SNAPSHOT/geowebcache-1.1-20090512.120147-8.jar
Note that it does perform an upgrade on the H2 database, so if the tiles are
valuable then please move them temporarily and start with an empty tree.Let me know if you have a chance to test it, your help would be greatly
appreciated.I just installed this here and tried it by starting a seed on a
somewhat complex layer and then trying to view it from the demo page.
Previously this would trigger the bug almost immediately, but despite
my best attempts at tripping it up I can’t make it fail anymore. I
think you nailed the bug!–
This message brought to you by Speed of Light Beer
When you’re approaching infinite mass
It’s Speed of Light time!
Message: 5
Date: Wed, 13 May 2009 08:05:51 -0700 (PDT)
Subject: Re: [Geoserver-users] Problems with GeoServer 1.7.4 and MySql
Message-ID: <23523704.post@anonymised.com.381…>
Content-Type: text/plain; charset=us-asciiHi,
I have test some diverent CREATE TABLES with a spatial column extention but
nothing works.Has anyone experiences with GeoServer 1.7.4 and MySql or could anyone test
the create definition of mine to exclude a failure of table creation or
spatial definition.It would be a greate thing,
Cheers 2StepForward
2StepForward wrote:
Hello,
POLYGONS
ID
NAME
THE_GEOM
polygon NOT NULL,
PRIMARY KEY (ID
but the THE_GEOM field is missed.
Thx 2StepForward
View this message in context: http://www.nabble.com/Problems-with-GeoServer-1.7.4-and-MySql-tp23521637p23523704.html
Message: 6
Date: Wed, 13 May 2009 11:13:08 -0400
Subject: Re: [Geoserver-users] new shapefile datastore how do I
connect to network drive data?
To: Andrea Aime <aaime@anonymised.com>
Cc: Daniel Buckley <dbuckley@anonymised.com186…>,
mitchelljj98@anonymised.com…, geoserver-users@lists.sourceforge.net
Message-ID:
<fa2ac0580905130813l298e2cfatf43b7ba2cd58f51c@anonymised.com>
Content-Type: text/plain; charset=“iso-8859-1”Andrea,
Regarding your comment:
- I remember there was an issue with the Windows services design
itself, like the inability to set a startup order, and the
fact Java cannot deal with UNC path directly (which would have
allowed to dodge the service startup order issue), but I cannot
find the thread in the archives with a quick search.*Is their a plan for future versions of Geoserver to allow connection to
files via UNC paths instead of via a mapped network drive?Thanks,
John Mitchell
On Wed, May 13, 2009 at 3:14 AM, Andrea Aime <aaime@anonymised.com> wrote:
John Mitchell ha scritto:
When creating a new shapefile datastore I filled in for the url field a
reference to a mapped network drive on the server (i.e.
file://j:/canada.shp) and I get an error “Could not find file:
J:\canada.shp”. When I try to reference the same file on the c drive it
finds with no error (i.e. file://c:/canada.shp)I just tried with a file on a remote drive on my XP VM and it
worked fine. In my case the path I specified was
file://z:/gisdata/roads.shpA difference that might be significant is that I have write access
on the remote drive.I also know that people in the past successfully connected
to shapefiles on remote drives, but then they found out they
could not go in production that way using GeoServer as a service
because the remote drives are mounted after the other services
are started.I remember there was an issue with the Windows services design
find the thread in the archives with a quick search.Cheers
Andrea–
Andrea Aime
Expert service straight from the developers.–
John J. Mitchell
An HTML attachment was scrubbed…
Message: 7
Date: Wed, 13 May 2009 08:18:40 -0700 (PDT)
Message-ID: <23523937.post@anonymised.com.381…>
Content-Type: text/plain; charset=us-asciiI need to make the realization of a pseudo-3D buildings. Something
similar to this
http://maps.google.com/maps?f=q&source=s_q&hl=ru&geocode=&q=New+York&sll=37.0625,-95.677068&sspn=48.240201,79.101563&ie=UTF8&ll=40.730202,-73.975502&spn=0.002837,0.004828&z=18&iwloc=AAndrea Aime-4 wrote:
Hello,
renderer does.
Andrea–
Andrea Aime
Expert service straight from the developers.Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users–
View this message in context: http://www.nabble.com/Custom-GTRender-tp23523268p23523937.html
Message: 8
Date: Wed, 13 May 2009 05:27:57 -0700 (PDT)
Message-ID: <23520788.post@anonymised.com.381…>
Content-Type: text/plain; charset=us-asciiHello!
Can I configure geoserver to use custom GTRender implementation class?
View this message in context: http://www.nabble.com/Custom-GTRender-tp23520788p23520788.html
Message: 9
Date: Wed, 13 May 2009 16:38:25 +0200
From: “Velarde Gutierrez, Victor” <victor.velarde@anonymised.com>
Subject: [Geoserver-users] URL CoverageStore ArcSDE 9.2 (Geos 1.7.4)
To: <geoserver-users@lists.sourceforge.net>
Message-ID:
<CF67985D0E48474B95C0939BC57A19C801866A6B@anonymised.com>
Content-Type: text/plain; charset=“us-ascii”Hello everybody,
I’m writing this email to ask about URL syntax for SDE raster (new
CoverageStore).I’m using the recommended way:
sde://user:pass@anonymised.com[:port]/[instance]#raster_table_name
But no matter how I write the slashes ("" or “/”), I always get the
message “Invalid url: ‘the_Url_I_Wrote’”.[Note: The plugin and my parameters seems to be ok, as I can get a working Feature with them (and use it with WMS / WFS)]
If instead of using the web application I directly edit the catalog.xml
sdeRasterEjemplo
file as in here:ArcSDE Raster
sde://myuser:mypassword@anonymised.com:5151/myGDB#MyRasterCatalog
and then I try to define a New Coverage with the web app, I get this
Exception:The following exception was thrown:
- class java.lang.IllegalArgumentException: ArcSDE Raster URL must
be of the form sde://user:pass@anonymised.com:port/[dbname]#rasterTableName -Got sde:\ myuser:mypassword @myHost:5151\myGDB#MyRasterCatalog
It seems that some Java operation inside has changed my slashes to an
incorrect form!!I found a similar topic in this list [
http://www.nabble.com/What’s-url-syntax-for-SDE-raster-in-GeoServer-1.7.
0-beta2-tt19544049.html#a19544049 ]This is my environment:
Windows Server 2003 Enterprise Edition SP2
Geoserver 1.7.4
Apache Tomcat/6.0.18 (JDK: 1.6.0_13-b03)
ArcSDE 9.2 SP6
Regards
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there’s a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you’ll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
https://lists.sourceforge.net/lists/listinfo/geoserver-usersEnd of Geoserver-users Digest, Vol 36, Issue 33
Γεώργιος Τσολάκης - Περιβαλλοντολόγος
Γραφείο Περιβαλλοντικών Μελετών
Ζήνωνος 57. Περιστέρι. Αθήνα
tel: +30 210 5727615
fax: +30 210 5727995
mobile: + 30 6977 158693
email: gtsolakis@anonymised.com
URL : www.mpe.gr
