[Geoserver-users] WFS-T : Error parsing message - saving objects very slow
hey folks
we recently experience the following geoserver issue while trying to save
objects (point/line) via mapbender:
saving an object needs at least some 20 secconds to save, whereas normally
we would expect about 2, 3 at most.
tracing the geoserver log file we get the following:
2012-11-27 10:55:45,437 WARN [geotools.xml] - Error parsing:
http://www.xxxxxx.de:8080/geoserver/wfs?typename=xxx:xxxxxxx
2012-11-27 10:55:45,531 INFO [geoserver.wfs] -
Request: transaction
  handle = null
  service = WFS
  version = 1.0.0
  baseUrl = http://www.xxxxxx:8080/geoserver/
  providedVersion = null
  extendedProperties = {}
  lockId = null
  group = [wfs:insert=net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com
(feature: [SimpleFeatureImpl:Schulradweg=[SimpleFeatureImpl.Attribute:
the_geom<the_geom id=fid--66bb80d9_13b3d17b329_-7ff8>=MULTILINESTRING
((3470440 5465780, 3472490 5466090, 3471210 5465310, 3470630 5465000))]],
handle: null, idgen: <unset>, inputFormat: <unset>, srsName: null)]
  insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com (feature:
  update =
  delete =
  native =
  releaseAction = ALL
(I exchanged the actual url with xxxxx)
any ideas what could be the reason for this behaviour?
regards, Oliver
View this message in context: http://osgeo-org.1560.n6.nabble.com/WFS-T-Error-parsing-message-saving-objects-very-slow-tp5019598.html
Hey Oliver,
Ca you provide some more information about the GeoServer data configuration? Basically how may stores / feature types / etc… are currently deployed.
If you have more than 100 feature types you probably want to increase the “feature type cache setting” in GeoServer. THe setting is on global settings page. The ideal setting is to make it larger than the number of total feature types configured in GeoServer.
-Justin
On Thu, Nov 29, 2012 at 7:37 AM, Oome <olliehoehn@anonymised.com> wrote:
hey folks
handle = null
service = WFS
version = 1.0.0
lockId = null
the_geom<the_geom id=fid–66bb80d9_13b3d17b329_-7ff8>=MULTILINESTRING
handle: null, idgen: , inputFormat: , srsName: null)]
insert = [net.opengis.wfs.impl.InsertElementTypeImpl@anonymised.com233… (feature:
update =
delete =
native =
releaseAction = ALL
regards, Oliver
Keep yourself connected to Go Parallel:
BUILD Helping you discover the best ways to construct your parallel projects.
http://goparallel.sourceforge.net
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
