hi @ all,
I am trying to insert geometries via "WFST-T - INSERT" in a PostGIS-DB.
With the Point-geometry it works fine but with a Line/Polygon geometry I get
an Error.
(Using GeoServer 1.5.4)
Request:
<wfs:Transaction version="1.0.0" service="WFS"
xmlns:gml="http://www.opengis.net/gml"
xmlns:topp="http://www.openplans.org/topp"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:wfs="http://www.opengis.net/wfs"
xsi:schemaLocation="http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd
http://localhost:8080/geoserver/wfs/DescribeFeatureType?typename=topp:geo_line">
<wfs:Insert>
<topp:geo_line>
<bezeichnung>line digi</bezeichnung>
<the_geom>
<gml:MultiLineString srsName="EPSG:31467">
<gml:lineStringMember>
<gml:LineString>
<gml:coordinates>3304000,5516000 3326000,5489000 3328000,5455000
3299000,5443000</gml:coordinates>
</gml:LineString>
</gml:lineStringMember>
</gml:MultiLineString>
</the_geom>
</topp:geo_line>
</wfs:Insert>
</wfs:Transaction>
Error:
<ServiceExceptionReport version="1.2.0"
xsi:schemaLocation="http://www.opengis.net/ogc
http://geoserver.lbd.rlp:80/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
java.lang.RuntimeException: problem creating feature
</ServiceException>
</ServiceExceptionReport>
Am I doing something wrong ?
Greq
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
Email: gregor.fikoczek@anonymised.com
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
info@anonymised.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Gregor Fikoczek ha scritto:
hi @ all, I am trying to insert geometries via "WFST-T - INSERT" in a PostGIS-DB.
With the Point-geometry it works fine but with a Line/Polygon geometry I get an Error.
Request:
<wfs:Transaction version="1.0.0" service="WFS" xmlns:gml="http://www.opengis.net/gml" xmlns:topp="http://www.openplans.org/topp" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wfs="http://www.opengis.net/wfs"
http://www.openplans.org/topp http://localhost:8080/geoserver/wfs/DescribeFeatureType?typename=topp:geo_line">
<wfs:Insert>
<topp:geo_line>
<the_geom>
<gml:LineString>
<gml:coordinates>3304000,5516000 3326000,5489000 3328000,5455000 3299000,5443000</gml:coordinates>
</gml:LineString>
</the_geom>
</topp:geo_line>
</wfs:Insert>
</wfs:Transaction>
Error:
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://geoserver.lbd.rlp:80/geoserver/schemas//wfs/1.0.0/OGC-exception.xsd">
<ServiceException>
java.lang.RuntimeException: problem creating feature </ServiceException>
Usually this happens when an attribute you've specified is incompatible with the actual type declared in the feature type. Can you go to config/server, enable verbose exceptions, and see if the error message is any more illuminating? Alternatively, have a look in the geoserver console (if you have one) or enable file logging and see what the full stack trace is.
Hi Andrea,
now I'm getting the following error message:
<?xml version="1.0" ?>
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
<ServiceException>
at
org.vfny.geoserver.wfs.requests.TransactionFeatureHandler.endElement(TransactionFeatureHandler.java:298)
at org.geotools.gml.GMLFilterGeometry.endElement(GMLFilterGeometry.java:203)
at org.geotools.gml.GMLFilterDocument.endElement(GMLFilterDocument.java:286)
at org.xml.sax.helpers.ParserAdapter.endElement(ParserAdapter.java:626)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown
Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.DTDConfiguration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.xml.sax.helpers.ParserAdapter.parse(ParserAdapter.java:405)
at
org.vfny.geoserver.wfs.requests.readers.TransactionXmlReader.read(TransactionXmlReader.java:78)
at
org.vfny.geoserver.servlets.AbstractService.doPost(AbstractService.java:435)
at org.geoserver.request.Dispatcher.post(Dispatcher.java:301)
at org.geoserver.request.Dispatcher.dispatch(Dispatcher.java:181)
at org.geoserver.request.Dispatcher.handleRequestInternal(Dispatcher.java:52)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at
org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:103)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:544)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
at
org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
at
org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
at
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
Caused by: IllegalAttribute: com.vividsolutions.jts.geom.LineString , but got
com.vividsolutions.jts.geom.MultiLineString
at org.geotools.feature.DefaultFeature.setAttribute(DefaultFeature.java:228)
at org.geotools.feature.DefaultFeature.setAttributes(DefaultFeature.java:269)
at org.geotools.feature.DefaultFeature.<init>(DefaultFeature.java:97)
at
org.geotools.feature.DefaultFeatureType.create(DefaultFeatureType.java:171)
at
org.geotools.feature.DefaultFeatureType.create(DefaultFeatureType.java:154)
at
org.vfny.geoserver.wfs.requests.TransactionFeatureHandler.endElement(TransactionFeatureHandler.java:287)
... 44 more
Caused by: java.lang.IllegalArgumentException:
com.vividsolutions.jts.geom.MultiLineString is not an acceptable class for
the_geom as it is not assignable from class
at
org.geotools.feature.DefaultAttributeType.validate(DefaultAttributeType.java:375)
at org.geotools.feature.DefaultFeature.setAttribute(DefaultFeature.java:225)
... 49 more
</ServiceException>
Greq
Am Montag, 14. Januar 2008 14:53:19 schrieb Andrea Aime:
> hi @ all,
> get an Error.
> Request:
>xsd http://www.openplans.org/topp
>_line"> <wfs:Insert>
> <topp:geo_line>
> <the_geom>
> <gml:LineString>
> </gml:LineString>
> </the_geom>
> </topp:geo_line>
> </wfs:Insert>
> </wfs:Transaction>
> Error:
>d"> <ServiceException>
> </ServiceException>
stack trace is.
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
info@anonymised.com
www.wheregroup.com
Komplementärin:
vertreten durch:
Hi Andrea,
Caused by: IllegalAttribute: com.vividsolutions.jts.geom.LineString , but got com.vividsolutions.jts.geom.MultiLineString
Here we go. You're trying to insert a multilinestring into a property
that's a linestring. They are not compatible.
Yet the original error message should have been more informative...
in fact there is a bug in the way we build the exception report:
http://jira.codehaus.org/browse/GEOS-1669
Hi Andrea,
thanks a lot for your hint,
i'm raeally trying to insert a MultiLine into a LineString... ,so I have to
change it
Best Regards,
Greq
Am Montag, 14. Januar 2008 16:55:31 schrieb Andrea Aime:
> Hi Andrea,
Siemensstraße 8
53121 Bonn
Germany
Gregor Fikoczek
info@anonymised.com
www.wheregroup.com
Komplementärin:
vertreten durch:
