[Geoserver-users] WFS-T request @ Geoserver 1.7.2
In a wfs-t request, where can i add an optional parameter like maxFeatures
or outputFormat in the request.
Request: (At Geoserver Sample Requests, the WFS_transactionUpdate.xml)
<wfs:Transaction service="WFS" version="1.0.0"
  xmlns:topp="http://www.openplans.org/topp&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:wfs="http://www.opengis.net/wfs&quot;&gt;
  <wfs:Update typeName="topp:tasmania_roads">
    <wfs:Property>
      <wfs:Name>TYPE</wfs:Name>
      <wfs:Value>street</wfs:Value>
    </wfs:Property>
    <ogc:Filter>
      <ogc:FeatureId fid="tasmania_roads.1"/>
    </ogc:Filter>
  </wfs:Update>
</wfs:Transaction>
Cumps,
D.Nunes
View this message in context: http://www.nabble.com/WFS-T-request-%40-Geoserver-1.7.2-tp22086352p22086352.html
Those parameters only appy to a GetFeature request, and will be ignored by transaction. They are attributes of the root GetFeature element.
-Justin
D.Nunes wrote:
    <wfs:Property>
    </wfs:Property>
    <ogc:Filter>
    </ogc:Filter>
  </wfs:Update>
</wfs:Transaction>
Cumps,
D.Nunes
Justin Deoliveira
OpenGeo - http://opengeo.org
There are any other parameters?
Or which parameters can i put in a wfs-t request?
Cumps.
D.Nunes
Justin Deoliveira-6 wrote:
-Justin
D.Nunes wrote:
maxFeatures
    <wfs:Property>
    </wfs:Property>
    <ogc:Filter>
    </ogc:Filter>
  </wfs:Update>
</wfs:Transaction>
Cumps,
D.Nunes
Justin Deoliveira
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco,
CA
-OSBC tackles the biggest issue in open source: Open Sourcing the
Enterprise
-Strategies to boost innovation and cut costs with open source
participation
-Receive a $600 discount off the registration fee with the source code:
SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-users mailing list
View this message in context: http://www.nabble.com/WFS-T-request-%40-Geoserver-1.7.2-tp22086352p22098105.html
Have a look at the official specifications for WFS 1.0
and WFS 1.1:
http://www.opengeospatial.org/standards/wfs
Andrea Aime
I download Geoserver 172 to test before using. I have installed pds_durbuy, and then I can see it on map. But I can do a simple wfs request:
<wfs:GetFeature service=“WFS” version=“1.0.0”
outputFormat=“GML2”
xmlns:topp=“http://www.openplans.org/topp
xmlns:durbuy=“http://www.d2d3.com/durbuy
xmlns:wfs=“http://www.opengis.net/wfs
xmlns:ogc=“http://www.opengis.net/ogc
xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance
xsi:schemaLocation=“http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd”>
<wfs:Query typeName=“durbuy:pds_durbuy”>
ogc:Filter
<ogc:FeatureId fid=“pds_durbuy.3”/>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
Result:
error:Translator error
Translator error
Error reading Features
Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT “gid”, “dolgis_gra”, “objectid”, “affect”, “sect_78”, “descriptio”, “art_cwatup”, “lien_walle”, “metadata”, “shape_leng”, “shape_area”, encode(asBinary(force_2d(“the_geom”),‘XDR’),‘base64’) FROM “public”.“pds_durbuy” WHERE () LIMIT 1000000
WHERE statement is empty.
Nguyễn Đình Toán
Neu khong doc duoc tieng Viet, vui long chon Encoding là Unicode (UTF-8). Cam on.
Toan Nguyen ha scritto:
<wfs:GetFeature service="WFS" version="1.0.0"
  outputFormat="GML2"
  xmlns:durbuy="http://www.d2d3.com/durbuy&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xsi:schemaLocation="http://www.opengis.net/wfs
                      http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
  <wfs:Query typeName="durbuy:pds_durbuy">
    <ogc:Filter>
       <ogc:FeatureId fid="pds_durbuy.3"/>
    </ogc:Filter>
    </wfs:Query>
</wfs:GetFeature>
Result:
Translator error
Could not aquire feature:org.geotools.data.DataSourceException: Error Performing SQL query: SELECT "gid", "dolgis_gra", "objectid", "affect", "sect_78", "descriptio", "art_cwatup", "lien_walle", "metadata", "shape_leng", "shape_area", encode(asBinary(force_2d("the_geom"),'XDR'),'base64') FROM "public"."pds_durbuy" WHERE () LIMIT 1000000
Hum, this is not looking good, the where clause should not have been
there, or be "where false" (if the only fid you provided is not
structurally valid for that table).
Most likely the issue is that your table does not have
a primary key, so the fid you specified cannot be matched back to
a filter on the (missing) primary key. Any fid that does not conform
to what GeoServer would generate gets removed before encoding (so
in this case the where clause should have been "where false", since
no record can satisfy your request).
Andrea Aime
Yeah, this table have no primary key. I have fixed, and it run well.
Thank you very much.
in this case the where clause should have been “where false”, since
Andrea Aime
Nguyễn Đình Toán
