On Wed, Mar 30, 2016 at 12:58 PM, Alessandro Pasotti <apasotti@anonymised.com>
wrote:
Hi All,
I'm testing the official geoserver 2.8.2 on Linux, I've enabled WFS-T
transactional on all workspaces.
I'm doing some insert tests using topp: roads, state_boundaries and cities
as test layers for linestrings, polygons and points.
Using QGIS as a client, this works:
- insert on cities
This doesn't:
- insert on roads and state_boundaries
First issue: geoserver returns <wfs:SUCCESS/> (no errors and no warnings
in the logs) but data are not inserted in the shapefiles.
By comparing example XML I've tracked down the problem (at least for
linestrings) to the simple GML used by QGIS, compared with the multi
geometry GML used in the geoserver demo requests (which works):
QGIS (silently fails):
<the_geom xmlns="http://www.openplans.org/topp">
<gml:LineString srsName="EPSG:4326">
<gml:coordinates cs="," ts=" ">146.1911....
GeoServer Demo Requests (works):
<topp:the_geom>
<gml:MultiLineString srsName="http://www.opengis.net/gml/srs/epsg.xml#4326
<gml:lineStringMember>
<gml:LineString>
<gml:coordinates decimal="." cs="," ts=" ">146.1911....
What geometry type is GeoServer declaring in DescribeFeatureType? If they
do not match you'll
get the result you are describing.
As far as I know the original developer of the WFS-T subsystem said we
cannot xml validate the
request for some reason, but at the same time the parser is unfortunately
schema driven,
meaning that it will only look for the elements it expects to find,
ignoring the others.
So if it's looking for a attribute that's not mandatory, and does not find
it because it's mis-encoded,
the transaction will succeeded ignoring the unexpected attributes.
We have had a number of reports due to this issue over the years, with a
few variants (e.g., people encoding
geometries in gml 2 in wfs 1.1 transactions), and I agree it would be best
if the
system validated the input xml against the expected schema and threw an
error,
but apparently it's not an easy thing to fix (meaning, not a spare time
deal),
and one that nobody has gathered funds to use working hours to fix so far.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
