I want to confirm if this is a bug, before I happily submit it to the issue tracker.
I’ve imported a shapefile into a PostGIS database. Here’s a part of the description:
Column | Type | Modifiers
gid | integer | not null default nextval(‘test_gid_seq’::regclass)
gm_code | character varying(16) |
gm_naam | character varying(30) |
postcode | character varying(11) |
dek_perc | bigint |
opp_tot | integer |
(omitted)
the_geom | geometry |
(My excuses for the bad formatting, if this occurs. I hope it will be readable enough.)
As you can see, there are a few strings, which have a maximum length.
Now, when I do a DescribeFeatureType on this feature (called pgtest:test), I’m gettting the following response:
xs:complexContent
<xs:extension base=“gml:AbstractFeatureType”>
xs:sequence
<xs:element name=“gm_code” minOccurs=“0” nillable=“true”>
xs:simpleType
<xs:restriction base=“xs:string”>
<xs:maxLength value=“2147483647”/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name=“gm_naam” minOccurs=“0” nillable=“true”>
xs:simpleType
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name=“postcode” minOccurs=“0” nillable=“true”>
xs:simpleType
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name=“dek_perc” minOccurs=“0” nillable=“true” type=“xs:long”/>
<xs:element name=“opp_tot” minOccurs=“0” nillable=“true” type=“xs:int”/>
<xs:element name=“the_geom” minOccurs=“0” nillable=“true” type=“gml:MultiPolygonPropertyType”/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
<xs:element name=‘test’ type=‘pgtest:test_Type’ substitutionGroup=‘gml:_Feature’/></xs:schema>
As you can see, the maxLength of the string properties (gm_code, gm_naam, postcode) are quite different from the values according to PostGIS. Is this a known issue? I couldn’t find any information on this in the issue tracker, and I had problems while searching this mailing list (but couldn’t find a hint either).
If I add the original shapefile as the datasource, the maxLength attributes contain the correct length.
This isn’t a problem while retrieving features, but it is for posting. I have entered a string which is too long (I didn’t think about the maxLength restriction), and Geoserver returned the following exception: wfs:Status<wfs:FAILED /></wfs:Status>wfs:MessageSome sort of database connection error: ERROR: value too long for type character varying(16)</wfs:Message>. Our software is able to cap the length of the entered string, based on the maxLength returned by DescribeFeatureType. The modifications are posted correctly, if the posted string value is short enough.
Frank Steggink
