[Geoserver-users] WFS-T success?
Hello,
Using the default installation of GeoServer 1.6.2 and the sample data:
I am sending TransactionRequests to the server, and the
TransactionResult (contained in TransactionResponse) has a status of
SUCCESS. However, it appears that nothing is changed on the server.
How do I diagnose what is going wrong if the server returns SUCCESS?
Also, the TransactionResponse always contain an InsertResult element;
for an Update or Delete, the fid = "none". Why is this?
Thanks for any insight...
Hi CB,
You can think of transactions as queries against the database, similar to a
SQL "UPDATE blah WHERE ..." command. That is, when you make a transaction
request, you are supplying a filter and modifying all the features that are
matched. If nothing matches that filter, then you successfully modify 0
features.
Short version: there's probably a typo in a literal or something in your
filter, look that over.
Hope this helps,
David Winslow
On Saturday 29 March 2008 11:25:37 CB wrote:
Hello,
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplac
e _______________________________________________
Geoserver-users mailing list
!DSPAM:4040,47ee5f7c39501439371379!
Are you using a maxFeature limit?
If so, you could not see a new feature if it's id is > of the max
Let's keep this on the mailing list, all of us are smarter than just me :slight_smile:
I don't see anything wrong with this request; does a feature with
fid=tiger_roads.8431 actually exist?
-David Winslow
On Monday 31 March 2008 10:08:18 CB wrote:
Thanks for the quick reply.
Is there anything to be learned from the GeoServer console? If I send
a simple Delete request, I see this on the console:
Request: transaction
        handle = null
        service = WFS
        version = 1.0.0
        baseUrl = http://69.54.29.26:8080/geoserver/
        lockId = null
        group =
[net.opengis.wfs:delete=net.opengis.wfs.impl.DeleteElementTypeIm pl@anonymised.com
(filter: [ tiger_roads.8341 ], handle: null, typeName: {http://www.cen
sus.gov}tiger_roads)]
        insert =
        update =
        delete = [net.opengis.wfs.impl.DeleteElementTypeImpl@anonymised.com
(filter: [ t iger_roads.8341 ], handle: null, typeName:
{http://www.census.gov}tiger_roads)] native =
        releaseAction = ALL
The TransactionRequest:
<?xml version="1.0" ?>
<wfs:Transaction
version="1.0.0"
service="WFS"
xmlns:wfs="http://www.opengis.net/wfs&quot;
xmlns:sde="http://geoserver.sf.net"
xmlns:tiger="http://www.census.gov"
xmlns:it.geosolutions="http://www.geo-solutions.it"
xmlns:nurc="http://www.nurc.nato.int"
xmlns:cite="http://www.opengeospatial.net/cite&quot;
xmlns:gml="http://www.opengis.net/gml&quot;
xmlns:ogc="http://www.opengis.net/ogc&quot;
xmlns="http://www.opengis.net/wfs&quot;
xsi:schemaLocation="http://www.opengis.net/wfs ../wfs/1.0.0/WFS-basic.xsd"
xmlns:sf="http://www.openplans.org/spearfish&quot;
xmlns:topp="http://www.openplans.org/topp&quot;
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
    <wfs:Delete typeName="tiger:tiger_roads">
        <ogc:Filter>
            <ogc:FeatureId fid="tiger_roads.8341"/>
        </ogc:Filter>
    </wfs:Delete>
</wfs:Transaction>
Thanks for your help.
CB
On Sat, Mar 29, 2008 at 11:34 AM, David Winslow <dwinslow@anonymised.com>
wrote:
> Hi CB,
> a SQL "UPDATE blah WHERE ..." command. That is, when you make a
> transaction request, you are supplying a filter and modifying all the
> features that are matched. If nothing matches that filter, then you
> successfully modify 0 features.
> Hope this helps,
> David Winslow
> > Hello,
> >-- Check out the new SourceForge.net Marketplace.
> >plac e _______________________________________________
> > Geoserver-users@lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geoserver-users
>ace _______________________________________________
!DSPAM:4040,47f0f058143153327367457!
Thanks for the reply.
When I get the features from the server, the wfs:FeatureCollection
contains this:
    <gml:featureMember>
        <tiger:tiger_roads fid="tiger_roads.8341">
            <tiger:the_geom>
                <gml:MultiLineString
srsName="http://www.opengis.net/gml/srs/epsg.xml#4326&quot;&gt;
                    <gml:lineStringMember>
                        <gml:LineString>
                            <gml:coordinates
xmlns:gml="http://www.opengis.net/gml&quot; decimal="." cs="," ts="
">-74.001465,40.735218 -74.003431,40.735238</gml:coordinates>
                        </gml:LineString>
                    </gml:lineStringMember>
                </gml:MultiLineString>
            </tiger:the_geom>
            <tiger:CFCC>Z99</tiger:CFCC>
            <tiger:NAME>One Ave W</tiger:NAME>
        </tiger:tiger_roads>
    </gml:featureMember>
The fid matches the fid in the Delete request, and matches what is
seen on the server's console.
On Mon, Mar 31, 2008 at 10:23 AM, David Winslow <dwinslow@anonymised.com> wrote:
-David Winslow
> handle = null
> service = WFS
> version = 1.0.0
> lockId = null
> group =
> insert =
> update =
> releaseAction = ALL
> <wfs:Transaction
> version="1.0.0"
> service="WFS"
> <ogc:Filter>
> </ogc:Filter>
> </wfs:Delete>
> </wfs:Transaction>
> CB
wrote:
> > Hi CB,
> > Hope this helps,
> > David Winslow
> > > Hello,
It appears Insert is working, while Update and Delete do not.
I am trying to find the differences in the TransactionRequests that
would explain the different results...
contains this:
    <gml:featureMember>
            <tiger:the_geom>
                        <gml:LineString>
                            <gml:coordinates
                        </gml:LineString>
            </tiger:the_geom>
> -David Winslow
> > handle = null
> > service = WFS
> > version = 1.0.0
> > lockId = null
> > group =
> > insert =
> > update =
> > releaseAction = ALL
> > <wfs:Transaction
> > version="1.0.0"
> > service="WFS"
> > <ogc:Filter>
> > </ogc:Filter>
> > </wfs:Delete>
> > </wfs:Transaction>
> > CB
> wrote:
> > > Hi CB,
> > > Hope this helps,
> > > David Winslow
> > > > Hello,
