[Geoserver-users] WFS-T Update and coordinate precision
Hallo,
using GeoServer to update polygons in an Oracle Locator database, we found out recently, that precision problems arise, when using GML to update features.
As the real world precision of the coordinates is lower than 1 cm and to minimize the size of GML documents, we set GeoServer to output coordinates with only 2 decimal places. But though the coordinates originally stored in the database also only had 2 decimal places, after manipulating the data using batch processes and desktop GIS software, the coordinates stored in double precision in the database have more significant numbers after the decimal point (i.e. 75.34 is now 75.3400000023561).
If we get a polygon with GetFeatures and update it using WFS-T, though the point has not been changed at all, we have 75.34 in the database, while in the neighbouing polygon the same point still has 75.3400000023561. Though in the real world this is not really relevant, for the software the two points are not the same anymore and there are intersections and holes between this polygon and the surrounding polygons.
The solution would be to set GeoServer to output for example 15 decimal places, but then all GetFeature requests, even those, that are only for display purposes, produce unnecessarily large GML documents. Also, for small coordinate values between 0 and 1, this only would work, if we could use floating point notation in GML, which to my knowlege is currently not possible in GeoServer.
Has anybody encountered the same problem and, if so, how has it been solved?
Best Regards,
Gerhard
Gerhard Sommer
Magistrat Wien (MA 14-ADV), Rathausstraße 1, 1082 Wien, Austria
E-Mail: gerhard.sommer@anonymised.com
Tel: +43 (1) 4000 91326
Fax: +43 (1) 4000 99 91326
Hi Gerhard,
I understand the issue. I am not aware of anyone running up against th is problem or any existing solutions.
I guess an ideal solution would be to allow you to specify the number of decimals in the request explicitly. We currently have the idea of format options for this. For example, if you wanted to make a getFeature for portrayal purposes:
...&request=getFeature&format_options=decimals:2
And for analyitcal purposes:
...&request=getFeature&format_options=decimals:15
Unfortunately this is not implemented. Although it would be fairly straight forward. If interested I suggest you create a new feature request in the issue tracker.
An alternative solution which could be implemented now is to use the GML-ZIP output format. It sends back compressed GML. The downside of this is that your client has to be prepared to unzip on download.
Hope that helps,
-Justin
Sommer Gerhard wrote:
Hallo,
Best Regards,
Gerhard
Gerhard Sommer
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
Hi Gerhard,
As yet another possible idea, what about writing an Oracle trigger
that reduces the coordinates precision on insert/update?
Cehers
Andrea Aime
How about trying to set tolerance in Oracle so that it won't even try to store coordinates with too many decimals? I have been thinking that perhaps the SDO_TOLERANCE parameter in DIMINFO(SDO_DIMNAME, SDO_LB, SDO_UB, SDO_TOLERANCE) in user_sdo_geom_metadata table exists for that reason but never bothered to study if it really is so.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Lähetetty: 8. tammikuuta 2009 16:54
Vastaanottaja: Sommer Gerhard
Kopio: geoserver-users@lists.sourceforge.net
Aihe: Re: [Geoserver-users] WFS-T Update and coordinate precision
Hi Gerhard,
Hope that helps,
-Justin
> Hallo,
has it been solved?
> Best Regards,
> Gerhard
> Gerhard Sommer
> -------- Check out the new SourceForge.net Marketplace.
> It is the best place to buy or sell services for just about
anything
> Open Source.
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
Justin Deoliveira
thank You for all the suggestions.
I thought about the tolerance myself, but though this is set to 1 mm in our feature types, it has no effect, when storing data or querying data for display. In these cases always all 15 digits are used (coordinates seem to be stored as double precision). As I understand it, this tolerance is only for comparing coordinates and it is not even certain, that it is used in every function, that in some way needs to test, if points are identical.
It would be fine, if the WFS standard could be extended to be able to choose the necessary precision in each request, as Justin suggested. But in my opinion this should not be a proprietary extension of GeoServer in the long term.
We use zipped GML and this might be the reason, that the performance is not as bad as I feared (though the digits can not be compressed any more). So it might make sense to always ouput the data with the full precision of the database. But this must be done in floating point notation (3.44324556501234E-3 instead of 0.00344324556501234). This also would circumvent the problem, if some of the data are stored projected in meters and some in decimal degrees, like EPSG:4326 (which needs much more digits after the comma to get the same precision).
Is it already possible somehow to switch to floating point notation in GML output somehow?
Best Regards,
Gerhard
Gerhard Sommer
-----Original Message-----
From: Rahkonen Jukka *EXTERN* [mailto:Jukka.Rahkonen@anonymised.com]
Sent: Thursday, January 08, 2009 4:10 PM
To: Sommer Gerhard
Subject: Re: [Geoserver-users] WFS-T Update and coordinate precision
-Jukka Rahkonen-
> Hi Gerhard,
> Hope that helps,
> -Justin
> > Hallo,
> has it been solved?
> > Best Regards,
> > Gerhard
> > Gerhard Sommer
> anything
> > Open Source.
> > _______________________________________________
> Justin Deoliveira
