Here is the console on my first attempt to perform the transaction, which has
been returning a parse exception at column 1, line 1, even though you said
the same transaction works for you. The second attempt at clicking the
submit button returns no response.
Here is what I see in the response box the first time I submit the
transaction:
XML Parsing Error: no element found
Line Number 1, Column 1:
The second time, the response box is empty. Here is what I see in the
console on the first attempt:
44507 [btpool0-6] INFO org.apache.struts.tiles.TilesRequestProcessor - Tiles
definition factory foun
d for request processor ''.
96125 [btpool0-5] INFO org.springframework.web.servlet.DispatcherServlet -
Initializing servlet 'dis
patcher'
96141 [btpool0-5] INFO org.springframework.web.servlet.DispatcherServlet -
FrameworkServlet 'dispatc
her': initialization started
96141 [btpool0-5] INFO /geoserver - Loading WebApplicationContext for Spring
tcher'
96156 [btpool0-5] INFO
org.springframework.beans.factory.xml.XmlBeanDefinitionReader - Loading XML
b
ean definitions from ServletContext resource
[/WEB-INF/dispatcher-servlet.xml]
96172 [btpool0-5] INFO
org.springframework.web.context.support.XmlWebApplicationContext - Bean
facto
ry for application context [WebApplicationContext for namespace
'dispatcher-servlet']: org.springfra
mework.beans.factory.support.DefaultListableBeanFactory defining beans
[requestDispatcher,filePublis
her,urlMapping]; parent:
org.springframework.beans.factory.support.DefaultListableBeanFactory defini
ng beans
[wms,wmsConfig,wmsRegisterar,wmsConfigRegisterar,wmsAbstractService,wmsService,wmsGetCapabi
lities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureType,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetM
ap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsReflect,GIFLegendProducerFactory,JaiLegendProducerFa
ctory,PNGLegendProducerFactory,PNGMapProducerFactory,GeoTiffMapProducerFactory,TiffMapProducerFactor
y,SVGMapProducerFactory,GIFMapProducerFactory,KMLMapProducerFactory,KMZMapProducerFactory,PDFMapProd
ucerFactory,JPEGMapProducerFactory,OpenLayersMapProducerFactory,GeoRSSMapProducerFactory,catalog,ser
viceFinder,applicationState,applicationStateRegisterar,validation,validationConfig,validationRegiste
rar,validationConfigRegisterar,config,geoServer,globalConfig,data,dataConfig,dataRegisterar,dataConf
igRegisterar,globalConfigRegisterar,geoServerRegisterar,speedServiceStrategy,fileServiceStrategy,buf
ferServiceStrategy,partialBufferServiceStrategy2,wfs,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfs
AbstractService,wfsService,wfsGetCapabilities,wfsDescribeFeatureType,wfsGetFeature,wfsLockFeature,wf
sGetFeatureWithLock,wfsTransaction,wcs,wcsConfig,wcsRegisterar,wcsConfigRegisterar,wcsAbstractServic
e,wcsService,wcsGetCapabilities,wcsDescribeCoverage,wcsGetCoverage]; root of
BeanFactory hierarchy
org.springframework.web.context.support.XmlWebApplicationContext - 3 beans
de
fined in application context [WebApplicationContext for namespace
org.springframework.web.context.support.XmlWebApplicationContext - Unable to
locate MessageSource with name 'messageSource': using default
[org.springframework.context.support.D
elegatingMessageSource@anonymised.com]
locate ApplicationEventMulticaster with name 'applicationEventMulticaster':
using default [org.sprin
gframework.context.event.SimpleApplicationEventMulticaster@anonymised.com]
org.springframework.ui.context.support.UiApplicationContextUtils - Unable to
locate ThemeSource with name 'themeSource': using default
[org.springframework.ui.context.support.De
legatingThemeSource@anonymised.com]
org.springframework.beans.factory.support.DefaultListableBeanFactory -
Pre-in
stantiating singletons in factory
[org.springframework.beans.factory.support.DefaultListableBeanFact
ory defining beans [requestDispatcher,filePublisher,urlMapping]; parent:
terar,wmsAbstractService,wmsService,wmsGetCapabilities,wmsGetCapabilitiesLegacy,wmsDescribeFeatureTy
pe,wmsGetFeatureInfo,wmsGetLegendGraphic,wmsGetMap,wmsGetMapLegacy,wmsPutStyles,kmlReflector,wmsRefl
ect,GIFLegendProducerFactory,JaiLegendProducerFactory,PNGLegendProducerFactory,PNGMapProducerFactory
,GeoTiffMapProducerFactory,TiffMapProducerFactory,SVGMapProducerFactory,GIFMapProducerFactory,KMLMap
ProducerFactory,KMZMapProducerFactory,PDFMapProducerFactory,JPEGMapProducerFactory,OpenLayersMapProd
ucerFactory,GeoRSSMapProducerFactory,catalog,serviceFinder,applicationState,applicationStateRegister
ar,validation,validationConfig,validationRegisterar,validationConfigRegisterar,config,geoServer,glob
alConfig,data,dataConfig,dataRegisterar,dataConfigRegisterar,globalConfigRegisterar,geoServerRegiste
rar,speedServiceStrategy,fileServiceStrategy,bufferServiceStrategy,partialBufferServiceStrategy2,wfs
,wfsConfig,wfsRegisterar,wfsConfigRegisterar,wfsAbstractService,wfsService,wfsGetCapabilities,wfsDes
cribeFeatureType,wfsGetFeature,wfsLockFeature,wfsGetFeatureWithLock,wfsTransaction,wcs,wcsConfig,wcs
Registerar,wcsConfigRegisterar,wcsAbstractService,wcsService,wcsGetCapabilities,wcsDescribeCoverage,
wcsGetCoverage]; root of BeanFactory hierarchy]
96188 [btpool0-5] INFO org.springframework.web.servlet.DispatcherServlet -
Using context class [org.
springframework.web.context.support.XmlWebApplicationContext] for servlet
'dispatcher'
Unable to locate Multipar
tResolver with name 'multipartResolver': no multipart request handling
provided
Unable to locate LocaleRe
solver with name 'localeResolver': using default
[org.springframework.web.servlet.i18n.AcceptHeaderL
ocaleResolver@anonymised.com]
96203 [btpool0-5] INFO org.springframework.web.servlet.DispatcherServlet -
Unable to locate ThemeRes
olver with name 'themeResolver': using default
[org.springframework.web.servlet.theme.FixedThemeReso
No HandlerAdapters found
in servlet 'dispatcher': using default
96219 [btpool0-5] INFO org.springframework.web.servlet.DispatcherServlet -
No ViewResolvers found in
her': initialization completed in 78 ms
Servlet 'dispatcher' conf
igured successfully
96234 [btpool0-5] INFO org.vfny.geoserver.requests.readers - getting request
type from org.vfny.geos
erver.util.requests.DispatcherHandler@anonymised.com
96281 [btpool0-5] INFO org.vfny.geoserver.servlets - handling request: Lock
releaseAction: ALL
handle: null
TypeName: topp:ch
handle: null topp:ch 1
ReleaseAll: true
filter: [ POP_ADMIN > 74307460 ]
Property - Name: COLOR_MAP, Value: 4
96531 [btpool0-5] INFO org.vfny.geoserver.servlets - Stream abruptly closed
by client, response abor
ted
View this message in context: http://www.nabble.com/WFS-T-Update-Works-only-one-time-tf4049356.html#a11506498
