Thanks. Seems to be an issue qith QGIS. The QGIS wfs-t request is not using an alias for the wfs namespace and is calling it directly. This is causing an error in processing. i will see if I can change this in QGIS.
–what I want
xmlns:wfs=“http://www.opengis.net/wfs”
<wfs:Update typeName=“cite:V_BUOYWFS”>
–what QGIS is doing
To: Robert Price rprice314@anonymised.com
Cc: “geoserver-users@lists.sourceforge.net” geoserver-users@lists.sourceforge.net
Sent: Tuesday, August 18, 2015 9:02 AM
Subject: Re: [Geoserver-users] WFS-T Updates and Oracle Spatial
On Tue, Aug 18, 2015 at 3:45 PM, Robert Price <rprice314@anonymised.com> wrote:
I am using geoserver 2.7.2 and QGIS 2.4 and am trying to update an Oracle spatial geometry via WFS-T. I got a Caused by: java.lang.ClassCastException: java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry error whenever I attempt the edit. Has anyone been successful in using Geoserver to do WFS-T updates on Oracle geometries? The request looks fine and the feature is defined as a Geometry so it seems like it should work.
BESTGEOMETRY<gml:Point srsName=“EPSG:4326”><gml:coordinates cs=“,” ts=" ">-104.01594128108584414,5.30989706503926229</gml:coordinates></gml:Point>
I don’t have time to check right now, but normally when that type of cast error happens, it means the parser was unable
to recognize that geometry as a valid one, and created a String instead.
Could there be a GML version mismatch for example? Like, the GML to define a point changes
from version to version.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
