[Geoserver-users] WFS unrecognized geometry element Surface
All,
I have a WFS I’m trying style through Geoserver for raster display. The WFS has a Surface element that is causing a error:
error:Translator error
Translator error
Unrecognized geometry element {http://www.opengis.net/gml}Surface
I found one Geotools discussion on this that basically says “request WFS 1.0” (http://osgeo-org.1560.x6.nabble.com/Wfsdatastore-and-gml3-parse-error-td4323645.html). But that doesn’t work in my case, nor is it an option. How do I get around this? Sees like there should be a way to have geoserver filter this element out or something.
WFS Server: http://egeoint.nrlssc.navy.mil/ogcserver/vector/nonstdmetadata?request=GetCapabilities&service=WFS
Feel free to take a look. (Oh, make your timeout around 60 seconds, it’s not very fast)
Mark
On Tue, Jul 23, 2013 at 10:24 PM, Mark Loper <mark_a_loper@anonymised.com> wrote:
All,
  I have a WFS I'm trying style through Geoserver for raster display. The
Translator error
Unrecognized geometry element {http://www.opengis.net/gml\}Surface
I found one Geotools discussion on this that basically says "request WFS
1.0" (
But that doesn't work in my case, nor is it an option. How do I get
The other way is to fix yourself the WFS cascading code and make it able to
parse Surface too. The change should not be
took complicated:
https://github.com/geotools/geotools/blob/master/modules/unsupported/wfs/src/main/java/org/geotools/data/wfs/v1_1_0/parsers/XmlSimpleFeatureParser.java
Or, look into the commercial support page at geoserver.org and find someone
that will implement the change for you
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks Aime!
That looks easy enough, although I haven’t tried compiling geotools so I’ll have to take a look at that. I don’t suppose anyone out there has done this already?? Surface seems pretty common, I’d just assume not reinvent if it already exists.
Mark
To: Mark Loper mark_a_loper@anonymised.com
Cc: Geoserver Geoserver-users@lists.sourceforge.net
Sent: Tuesday, July 23, 2013 5:04 PM
Subject: Re: [Geoserver-users] WFS unrecognized geometry element Surface
On Tue, Jul 23, 2013 at 10:24 PM, Mark Loper mark_a_loper@anonymised.com wrote:
All,
Translator error
The other way is to fix yourself the WFS cascading code and make it able to parse Surface too. The change should not be
took complicated:
Or, look into the commercial support page at geoserver.org and find someone that will implement the change for you
Ing. Andrea Aime
@geowolf
Technical Lead
On Tue, Jul 23, 2013 at 11:25 PM, Mark Loper <mark_a_loper@anonymised.com> wrote:
Thanks Aime!
That looks easy enough, although I haven't tried compiling geotools so
I'll have to take a look at that. I don't suppose anyone out there has
done this already?? Surface seems pretty common, I'd just assume not
A search in the GeoTools Jira did not turn out anything, and we never
received a pull request for this so... I guess not?
I'm cc'ing Mauro too, as he was the last one to work on the WFS store.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
It looks like it’s only the one Jar file and about 3 lines of code. I would prefer this be part of the baseline as opposed to a custom change. I’m happy to go through the process to submit the update, spent a good part of yesterday reading up on that.
-M
To: Mark Loper mark_a_loper@anonymised.com; Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com…1107…>
Sent: Wednesday, July 24, 2013 1:59 AM
Thanks Aime!
A search in the GeoTools Jira did not turn out anything, and we never received a pull request for this so… I guess not?
I’m cc’ing Mauro too, as he was the last one to work on the WFS store.
Ing. Andrea Aime
@geowolf
Technical Lead
On Wed, Jul 24, 2013 at 5:22 PM, Mark Loper <mark_a_loper@anonymised.com> wrote:
It looks like it's only the one Jar file and about 3 lines of code. I
I'm happy to go through the process to submit the update, spent a good
Sure, contributions are welcomed
information.
Ing. Andrea Aime
@geowolf
Technical Lead
