Hi again,
I'm trying to update the geom of a feature object with POST. But
geoserver doesn't update the geom due to a db connection error (Its a
postgis DB latest stable).
Im using GeoServer NightyBuild "geoserver-1.5.x-071707-bin"
Am i doing something wrong or is it a bug?
If you need more details/schema/shapefile/etc just ask
Thanks for the great job done in this community.
--Jeremy
Here the POST Content (Removed some points inside):
// --------- START ----------
<wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
version="1.0.0" xmlns:gml="http://www.opengis.net/gml"
xmlns:icia="http://www.test.com/icia"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<wfs:Update wfs:typeName="icia:batiment_prive">
<ogc:Filter>
<ogc:FeatureId fid="batiment_prive.276"/>
</ogc:Filter>
<the_geom>
<gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg.xml#27592">
<gml:polygonMember>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates>-1022589.92,-7819210
-1024089.26,-7820992.060000001 -1022589.92,-7819210 </gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</gml:polygonMember>
</gml:MultiPolygon>
</the_geom>
</wfs:Update>
</wfs:Transaction>
// --------- END ----------
The geom type of my feature is "gml:MultiPolygonPropertyType" so it
seems correct to me.
The response of geoserver is:
<wfs:WFS_TransactionResponse version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/wfs
http://xxx.xxx.xxx.xxx:8080/geoserver/schemas/wfs/1.0.0/WFS-transaction.xsd">
<wfs:TransactionResult> <wfs:Status> <wfs:FAILED/> </wfs:Status>
<wfs:Message>Some sort of database connection error: ERROR: syntax
error at or near "WHERE"</wfs:Message>
</wfs:TransactionResult></wfs:WFS_TransactionResponse>
Here last lines of the log talking about the error:
FINER: encoded modify is UPDATE "public"."batiment_prive" SET WHERE
("gid" = '276');
Jul 19, 2007 11:54:41 AM org.geotools.filter.FidFilterImpl equals
FINEST: condition: [ batiment_prive.276 ]
FINEST: condition: 22
Jul 19, 2007 11:54:41 AM AbstractFilter isLogicFilter
FINER: ENTRY 22
Jul 19, 2007 11:54:41 AM org.geotools.filter.SQLEncoder visit
FINER: Exporting FID=[batiment_prive.276]
Jul 19, 2007 11:54:41 AM org.geotools.data.postgis.PostgisFeatureStore
getEnvelope
FINE: SQL: SELECT AsText(force_2d(Envelope(Extent("the_geom")))) FROM
"public"."batiment_prive" WHERE ("gid" = '276')
Jul 19, 2007 11:54:41 AM org.geotools.data.postgis.PostgisFeatureStore bounds
FINER: returning bounds Env[8.4876752E7 : 8.4879768E7, -7819432.0 : -7813849.0]
modifyFeatures
WARNING: Some sort of database connection error: ERROR: syntax error
at or near "WHERE"
Jul 19, 2007 11:54:41 AM org.vfny.geoserver.servlets.AbstractService doService
FINER: execution succeed
FINEST: getting strategy output
FINER: strategy output is: java.io.BufferedOutputStream
FINE: mime type is: text/xml; charset=UTF-8
org.geotools.data.jdbc.ConnectionPool$ConnectionListManager
connectionClosed
FINE: Connection closed - adding to available connections.
INFO: Service handled
