As soon as I upgradeed to 1.6.0b4 (and later to 1.6.0rc1), I noticed the use of "*" as propertyname, as in:
http://localhost:8080/geoserver/wfs?
request=GetFeature
&version=1.0.0
&propertyname=*
&featureversion=1
&typename=sdm:GEOREGIONISTAZIONI
triggered a "java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0", which didn't occur with 1.5.x; if I use an empty value for the propertyname, it works fine.
I've searched Jira but this issue seems non to be in the list: what should I do ?
Luca Morandini
www.lucamorandini.it
Is propertyname=* part of the spec? It's just supposed to retrieve all?
Whey don't you just not use the propertyname parameter?
Chris
request=GetFeature
&version=1.0.0
&propertyname=*
&featureversion=1
Luca Morandini
Defy all challenges. Microsoft(R) Visual Studio 2005.
Geoserver-users mailing list
!DSPAM:4005,4742007777351628642973!
<<A list of properties may be specified for
each feature type that is being queried.
Refer to subclause 14.2.2 on how to form
lists of parameters. A "*" character can be
used to indicate that all properties should
be retrieved. There is a 1:1 mapping
between each element in a FEATUREID or
TYPENAME list and the
PROPERTYNAME list. The absense of a
value also indicates that all properties
should be fetched.>>
From the WFS 1.1.0 spec, page 99.
Sure I can... but the use of "*" should be allowed too, if I understand the spec correctly.
Luca Morandini
Luca Morandini
Huh. I thought I knew the WFS spec and don't remember that one, though maybe it wasn't in 1.0? CITE doesn't test it, or else it'd definitely be in there.
Could you make a bug report for it? Schedule against RC2.
thanks,
Chris
Luca Morandini
!DSPAM:4005,47420c86107401015089218!
Glad an extra pair of eyeballs may help sometimes
It was in 1.0 too, at page 65.
Done, GEOS-1525.
Luca Morandini
