[Geoserver-users] wfsGetFeature-Problem
Hello!
I’ve just got a problem concerning “wfsGetFeature”-Request in Geoserver 1.3.3.
When I’m trying to request the Feature Infos from an Oracle-FeatureType (PUBLICTRAFFIC) I’m getting the following error message:
javax.xml.transform.TransformerException: Translator error
I’ve got a primary Key-Constraint and a spatial Index defined for the oracle table PUBLICTRAFFIC (feature class).
The LOG-File tells me:
21.08.2006 12:32:28 org.geotools.data.jdbc.JDBC1DataStore executeQuery
SCHWERWIEGEND: Error Performing SQL query: SELECT “PK_PTRAFFIC”, “PUBTRAF_ID”, “COUNTRY_ID”, “CAT_ID”, “NETWORK_ID”, “DIR_ID”, “FLOOR_ID”, “CONST_ID”, “FOREIGN_ID”, “FOREIGNKEY”, “MODDATE_A”, “MODOPER_A”, “MODDATE_G”, “MODOPER_G”, “CREATEDATE”, “CREATEOPER”, “GEOM” FROM “PUBLICTRAFFIC” WHERE
java.sql.SQLException: ORA-00921: unexpected end of SQL command
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:125)
at oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:681)
at oracle.jdbc.driver.T2CConnection.checkError(T2CConnection.java:614)
at oracle.jdbc.driver.T2CStatement.execute_for_describe(T2CStatement.java:841)
at oracle.jdbc.driver.OracleStatement.execute_maybe_describe(OracleStatement.java:942)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1037)
at oracle.jdbc.driver.OracleStatement.executeQuery(OracleStatement.java:1183)
at org.geotools.data.jdbc.JDBC1DataStore.executeQuery(JDBC1DataStore.java:897)
at org.geotools.data.jdbc.JDBC1DataStore.getFeatureReader(JDBC1DataStore.java:656)
at org.geotools.data.jdbc.JDBCFeatureCollection.reader(JDBCFeatureCollection.java:78)
at org.geotools.data.DefaultFeatureResults.getBounds(DefaultFeatureResults.java:193)
at org.geotools.gml.producer.FeatureTransformer$FeatureTranslator.encode(FeatureTransformer.java:389)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:611)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:463)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:293)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:126)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:105)
at org.vfny.geoserver.wfs.responses.GML2FeatureResponseDelegate.encode(GML2FeatureResponseDelegate.java:225)
at org.vfny.geoserver.wfs.responses.FeatureResponse.writeTo(FeatureResponse.java:141)
at org.vfny.geoserver.servlets.AbstractService.doService(AbstractService.java:527)
at org.vfny.geoserver.servlets.AbstractService.doGet(AbstractService.java:279)
at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doResponse(WfsDispatcher.java:284)
at org.vfny.geoserver.wfs.servlets.WfsDispatcher.doGet(WfsDispatcher.java:213)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:358)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:342)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:122)
at org.mortbay.jetty.servlet.WebApplicationHandler$Chain.doFilter(WebApplicationHandler.java:334)
at org.mortbay.jetty.servlet.WebApplicationHandler.dispatch(WebApplicationHandler.java:286)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:567)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1807)
at org.mortbay.jetty.servlet.WebApplicationContext.handle(WebApplicationContext.java:525)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1757)
at org.mortbay.http.HttpServer.service(HttpServer.java:879)
at org.mortbay.http.HttpConnection.service(HttpConnection.java:790)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.java:961)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:807)
at org.mortbay.http.SocketListener.handleConnection(SocketListener.java:197)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:276)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:511)
I ask myself where is the WHERE-clause?
Did I configure something wrong or missed a definition in the config.xml?
Did I forgot something in defining the FeatureType?
A request like
http://localhost/geoserver/wfs?request=GetFeature&version=1.0.0&propertyname=*&featureversion=1&typename=NT18:PUBLICTRAFFIC&featureid=PUBLICTRAFFIC.1515
works great!
Thanks in advance for any help!
Best regards,
Dirk
Hi Dirk,
Could you show us the request you are using? We can help find the problem then.
From that error it looks like you aren't passing in any constraints, and that is causing it to barf.
Brent Owens
(The Open Planning Project)
Dirk Buechel wrote:
Hello!
I've just got a problem concerning "wfsGetFeature"-Request in Geoserver 1.3.3.
When I'm trying to request the Feature Infos from an Oracle-FeatureType (PUBLICTRAFFIC) I'm getting the following error message:
I've got a primary Key-Constraint and a spatial Index defined for the oracle table PUBLICTRAFFIC (feature class).
SCHWERWIEGEND: Error Performing SQL query: SELECT "PK_PTRAFFIC", "PUBTRAF_ID", "COUNTRY_ID", "CAT_ID", "NETWORK_ID", "DIR_ID", "FLOOR_ID", "CONST_ID", "FOREIGN_ID", "FOREIGNKEY", "MODDATE_A", "MODOPER_A", "MODDATE_G", "MODOPER_G", "CREATEDATE", "CREATEOPER", "GEOM" FROM "PUBLICTRAFFIC" WHERE
A request like
works great!
Best regards,
Dirk
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
