[Geoserver-users] WG: AW: AW: WMS: cannot change maxConnections
Hi Gabriel,
i was just setting up a new environment. Java 6, tomcat 6.0.18 and geoserver 1.7.0. I also added the necessary ArcSDE client jars for ArcSDE 9.3 - jsde93_sdk.jar and jpe93_sdk.jar. Furthermore i installed the ArcSDE datastore jars gt-arcsde-2.5.1.jar, jsqlparser and commons-pool.jar. But i cannot create an ArcSDE datastore. I get the errormessage: "cannot create a validated object". When looking into the the ArcSDE-log i noticed that the connection from geoserver to SDE was successful. But GS doesn't hold it. The problem is surely not on SDE-side, because with the former 1.7.0-installation the datastore connection succeeded. Can it be something with the new environment (because its the only thing that is different now) - maybe a jar is needed when running java 6 or something like this?
Best regards
Albrecht
Albrecht Weiser,
E6, GIS Center
Hessische Zentrale für Datenverarbeitung (HZD)
Mainzer Straße 29, 65185 Wiesbaden
Tel.: 0611 340-3113
Fax: 0611 340-5113
E-Mail: albrecht.weiser-at-hzd.hessen.de
Von: Gabriel Roldan [mailto:groldan@anonymised.com]
Gesendet: Freitag, 7. November 2008 14:43
An: Weiser, Albrecht (HZD)
Betreff: Re: AW: AW: [Geoserver-users] WMS: cannot change
maxConnections
On Friday 07 November 2008 11:31:37 am you wrote:
> OK, i'll do so. The maxConnection was by default at 6, so
it was OK from
> this side, but nevertheless so slow. To exclude some
dependencies, i'll
> setup a totally new environment based on new java, tomcat
and geoserver and
> i'll also put the old tomcat/geoserver out of service and
then do again the
> benchmark. The latter test was quick'n dirty. Now from
scratch. But that
> will take some time. It will be surely next week until i
get back to you.
ok, don't worry about that, it's not like I'm super free
neither but this is
something worth digging into.
have fun.
Gabriel
> Best wishes
> Albrecht
> Albrecht Weiser,
> E6, GIS Center
> Tel.: 0611 340-3113
> Fax: 0611 340-5113
> > Gesendet: Freitag, 7. November 2008 13:36
> > Betreff: Re: AW: [Geoserver-users] WMS: cannot change
maxConnections
> > That's bad news... and in theory it shouldn't be
slower... what about
> > maxConnections? did the problem persist or were you able to
> > increase the
> > number of available connections?
> > please do me a favor, enable the GEOTOOLS_DEVELOPER_LOGGING
> > logging profile an
> > send me back the geoserver.log by private email.
> > Also please tell me about your environment, number and
> > average dataset
> > complexity (shape type, shape complexity, number of shapes),
> > number of
> > layers, sde version, backend RDBMS etc.
> > I'll see if I can set up a comparative benchmark over against
> > the two versions
> > but this things are usually hard to diagnose.. for the test
> > datasets I used
> > (client's data) when developed the improved arcsde extensions
> > it probed to be
> > faster and more reliable... but one never know,
regressions happen.
> > Cheers,
> > Gabriel
> > On Friday 07 November 2008 06:30:59 am you wrote:
> > > Hi Gabriel,
> > > thanks for answering. I installed 1.7.0 (By the way it
> > serves just "?" for
> > > the special german characters - It should better be
compiled with
> > > iso8859-1). When testing with jmeter it was VERY slow!! The
> > average was 22
> > > seconds for all 50 requests while answering times for UMN
> > mapserver and
> > > ArcIMS for the same requests are between 3 to 7 seconds.
> > That's not ok for
> > > a productive environment. I installed the 1.7.0 on the same
> > tomcat where
> > > 1.6.3 is running on. The tomcat is of release 5.5.26 and it
> > uses java 5. I
> > > know, that for geoserver are newer components
recommended, but is it
> > > possible, that 1.7.0 is much slower than 1.6.3 in the same
> > environment?
> > > Best wishes
> > > Albrecht
> > > Albrecht Weiser,
> > > E6, GIS Center
> > > Tel.: 0611 340-3113
> > > Fax: 0611 340-5113
> > > > Gesendet: Donnerstag, 6. November 2008 17:22
> > > > An: geoserver-users@lists.sourceforge.net
> > > > Cc: Weiser, Albrecht (HZD)
> > > > Betreff: Re: [Geoserver-users] WMS: cannot change
maxConnections
> > > > Hi albercht,
> > > > I notice you're using geoserver 1.6.3. Hence, I suggest you
> > > > to try out with a
> > > > newer version (1.7.0 should work) since the arcsde plugin was
> > > > improved a big
> > > > deal since 1.6.3, and one of the aspects it got better is on
> > > > connection
> > > > handling.
> > > > I'm not sure why exactly you're getting that behaviour in
> > > > 1.6.3, but truth is,
> > > > that's dead code no longer maintained so if you can switch to
> > > > a newer version
> > > > that'd be great.
> > > > Waiting for your comments.
> > > > Cheers,
> > > > Gabriel
> > > > On Thursday 06 November 2008 02:04:18 pm
> > > > Albrecht.Weiser@anonymised.com wrote:
> > > > > Hi list,
> > > > > i'm doing some stress tests on geoserver with the apache
> > > > jmeter tool. I'm
> > > > > simulating 5 concurrent users (by 5 threads) each with
> > 10 sequential
> > > > > requests in an interval of 1 second (alltogether 50
> > requests in 10
> > > > > seconds). That shouldn't be too much for geoserver because
> > > > it's running on
> > > > > a double quad core machine with 16GB RAM and WIN 2003
> > > > platform. As Backend
> > > > > i am using ArcSDE on Oracle (i'm using geoserver 1.6.3,
> > > > tomcat 5.5.26) I
> > > > > was just getting a handful of images back from geoserver
> > > > with every test
> > > > > while the vast majority didn't work . When looking at the
> > > > log, i found this
> > > > > error: "java.util.NoSuchElementException: Could not aquire
> > > > > feature:org.geotools.data.DataSourceException: The
> > maximun of 2 to
org.geotools.arcsde.pool.ArcSDEConnectionConfig[dbtype=arcsde,
> > > > > server=srvumwgeo005.umwelt.hessen.de, port=5151,
instance=null,
> > > > > user=geoview_user, password=*****, minConnections=2,
> > > > maxConnections=2,
> > > > > connTimeOut=1000] has been reached" Hence i was changing
> > > > the datastore
> > > > > configuration. Setting up the pool.maxConnections up to 8
> > > > and the pool
> > > > > timeout up to 8000ms. That showed no success. Still the
> > > > same error. Even
> > > > > the "maxConnections=2, connTimeOut=1000" was still the same
> > > > and didn't
> > > > > change (Although the configuration window shows the
> > right values). I
> > > > > restartet tomcat. Still the same error. I restarted the
> > whole server
> > > > > (sometimes its necessary on windows machines). Still the
> > > > same. It looks
> > > > > like my settings of maxConnections wasn't beeing taken from
> > > > geoserver. I
> > > > > also stopped some other services to release connections to
> > > > ArcSDE and
> > > > > increased the maximum numbers of connections of ArcSDE. But
> > > > still the same
> > > > > with geoserver WMS. It looks like the problem is
> > > > geoserver-side. I attached
> > > > > a verbose log of the last test to the mail. Hope that
> > > > someone knows where
> > > > > the problem could be. Thanks
> > > > > Albrecht
> > > > > Albrecht Weiser,
> > > > > E6, GIS Center
as long as I can tell, GeoServer is not testes with ArcSDE 9.3. There may be
some issues with it, seems likely, but I can't tell until able to test over a
9.3 instance.
What about the geoserver log, does it tell something? could you send me the
geoserver.log file by private email?
Gabriel
On Monday 10 November 2008 09:00:38 am Albrecht.Weiser@anonymised.com wrote:
Hi Gabriel,
- maybe a jar is needed when running java 6 or something like this? Best
regards
Albrecht
Albrecht Weiser,
E6, GIS Center
Tel.: 0611 340-3113
Fax: 0611 340-5113
> maxConnections
> it was OK from
> dependencies, i'll
> and geoserver and
> then do again the
> scratch. But that
> get back to you.
> neither but this is
> have fun.
> Gabriel
> > Best wishes
> > Albrecht
> > Albrecht Weiser,
> > E6, GIS Center
> > Tel.: 0611 340-3113
> > Fax: 0611 340-5113
> maxConnections
> > > increase the
> > > logging profile an
> > > average dataset
> > > number of
> > > the two versions
> > > datasets I used
> > > it probed to be
> regressions happen.
> > > Cheers,
> > > Gabriel
> > > > Hi Gabriel,
> > > serves just "?" for
> compiled with
> > > average was 22
> > > mapserver and
> > > That's not ok for
> > > tomcat where
> > > uses java 5. I
> > > environment?
> > > > Best wishes
> > > > Albrecht
> > > > Albrecht Weiser,
> > > > E6, GIS Center
> > > > Tel.: 0611 340-3113
> > > > Fax: 0611 340-5113
> maxConnections
> > > > > Hi albercht,
> > > > > to try out with a
> > > > > improved a big
> > > > > connection
> > > > > handling.
> > > > > a newer version
> > > > > that'd be great.
> > > > > Cheers,
> > > > > Gabriel
> > > > > > Hi list,
> > > > > jmeter tool. I'm
> > > 10 sequential
> > > requests in 10
> > > > > it's running on
> > > > > tomcat 5.5.26) I
> > > > > with every test
> > > > > log, i found this
> > > maximun of 2 to
> instance=null,
> > > > > maxConnections=2,
> > > > > the datastore
> > > > > and the pool
> > > > > same error. Even
> > > > > and didn't
> > > right values). I
> > > whole server
> > > > > same. It looks
> > > > > geoserver. I
> > > > > ArcSDE and
> > > > > still the same
> > > > > someone knows where
> > > > > > Albrecht
> > > > > > Albrecht Weiser,
> > > > > > E6, GIS Center
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge Build the coolest Linux based applications with Moblin SDK & win
great prizes Grand prize is a trip for two to an Open Source event anywhere
in the world http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
I've run into this problem with ArcSDE 9.3 as well, using java 1.5.0, tomcat 5.5 and GeoServer 1.7.2. Were you able to resolve the problem?
Mark Leslie
Gabriel Roldan wrote:
as long as I can tell, GeoServer is not testes with ArcSDE 9.3. There may be some issues with it, seems likely, but I can't tell until able to test over a 9.3 instance.
What about the geoserver log, does it tell something? could you send me the geoserver.log file by private email?
Gabriel
Hi Gabriel,
regards
Albrecht
Albrecht Weiser,
E6, GIS Center
Tel.: 0611 340-3113
Fax: 0611 340-5113
maxConnections
it was OK from
dependencies, i'll
and geoserver and
then do again the
scratch. But that
get back to you.
neither but this is
have fun.
Gabriel
Best wishes
Albrecht
Albrecht Weiser,
E6, GIS Center
Tel.: 0611 340-3113
Fax: 0611 340-5113
maxConnections
increase the
logging profile an
average dataset
number of
the two versions
datasets I used
it probed to be
regressions happen.
Gabriel
Hi Gabriel,
serves just "?" for
compiled with
average was 22
mapserver and
That's not ok for
tomcat where
uses java 5. I
environment?
Best wishes
Albrecht
Albrecht Weiser,
E6, GIS Center
Tel.: 0611 340-3113
Fax: 0611 340-5113
maxConnections
Hi albercht,
to try out with a
improved a big
connection
handling.
a newer version
that'd be great.
Gabriel
Hi list,
jmeter tool. I'm
10 sequential
requests in 10
it's running on
tomcat 5.5.26) I
with every test
log, i found this
maximun of 2 to
instance=null,
maxConnections=2,
the datastore
and the pool
same error. Even
and didn't
right values). I
whole server
same. It looks
geoserver. I
ArcSDE and
still the same
someone knows where
Albrecht
Albrecht Weiser,
E6, GIS Center
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
Gabriel is travelling so I believe he won't be able to answer/fix for
maybe a week, but as far as I know we only have a 9.2 handy, so we might
not be able to reproduce the issue to start with.
Andrea Aime
OpenGeo - http://opengeo.org
Thanks for the warning. I've only got 9.3 here, but at the moment I can't make it publicly accessible. I do have a Jody though, so I'll see what I can figure out with that.
Mark
