[Geoserver-users] WG: Coordinate Reference System EPSG:3068
Hello,
is there a possibility to add support for the CRS with the EPSG-Code EPSG:3068 to GeoServer? I have try to fit the file epsg.properties in the data-directory with the following line, but it doesnt't work.
3068=PROJCS["DHDN / Soldner Berlin",GEOGCS["DHDN",DATUM["Deutsches_Hauptdreiecksnetz",SPHEROID["Bessel 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],AUTHORITY["EPSG","6314"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4314"]],PROJECTION["Transverse Mercator"],PARAMETER["latitude_of_origin",52.41864827777778],PARAMETER["central_meridian",13.62720366666667],PARAMETER["false_easting",40000],PARAMETER["false_northing",10000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","3068"]]
I think the parametervalue "Transverse Mercator" is incorrect, but GeoServer doesn't accepts the parametervalue "Soldner", which is specified in PROJ.4.
Best regards
Tino Desjardins
I believe that the problem is that Geotools does not support the Soldner projection as you state (i could be wrong). What issue are you seeing when you change the projection? A blank map when you zoom to the relevant area?
Hopefully Martin or Andrea (our referencing experts) will have more useful information for you.
-Justin
dejavuesnd@anonymised.com wrote:
Hello,
Best regards
Tino Desjardins
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
Geoserver-users mailing list
!DSPAM:4007,47f203f3326833327367457!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Right, current GeoTools code do not known about "Cassini-Soldner" projection. We would need a volunter for implementing it (usually the task is a single Proj4 C file to port to Java).
  Martin
Cool,
I have created a jira task for this:
http://jira.codehaus.org/browse/GEOT-1757
Now all we need is a voluneteer... :slight_smile:
    Martin
!DSPAM:4007,47f2604d180633362379201!
Justin Deoliveira
