Thanks. I tried installing the CSS extension but now my geoserver instance
wont start anymore.
I'm using geoserver stable 2.2.2 and used the 2.2.x version of the CSS
extension.
I also tried removing the files from the extension with no success.
I only get the standard jetty "SERVICE UNAVAILABLE"
Here is the full log:
David Winslow-5 wrote
lysgaard@anonymised.com:~/oam/geoserver/geoserver-2.2.2$ ./bin/startup.sh
GEOSERVER_HOME environment variable not found, using current
directory. If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is
/home/lysgaard/oam/geoserver/geoserver-2.2.2/data_dir
1 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
240 [main] WARN org.mortbay.log - Deprecated configuration used for
/home/lysgaard/oam/geoserver/geoserver-2.2.2/webapps
268 [main] INFO org.mortbay.log - jetty-6.1.8
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
1354 [main] INFO /geoserver - Initializing Spring root
WebApplicationContext
03 Jan 19:40:39 WARN [config.CustomEditorConfigurer] - Passing
PropertyEditor instances into CustomEditorConfigurer is deprecated: use
PropertyEditorRegistrars or PropertyEditor class names instead. Offending
key [org.geotools.util.Version; offending editor instance:
org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
Jan 3, 2013 7:40:39 PM org.geoserver.platform.GeoServerExtensions
checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
03 Jan 19:40:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR:
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'tiger_roads'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'poly_landmarks'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'restricted'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'rain'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'grass'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'simple_streams'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'cite_lakes'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'polygon'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'simple_roads'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'line'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'pophatch'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'green'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'poi'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'point'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'capitals'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'raster'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'burg'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'population'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'giant_polygon'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'dem'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded default workspace OAM
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'sde'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'tiger'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'cite'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'topp'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'nurc'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'OAM'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_navaids'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_labels'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_forests'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_countorlines'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_waters'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_runways'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_cities'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_city_markers'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_airspaces'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_peaks'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_hillshade'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded style 'oam_roads'
03 Jan 19:40:39 INFO [org.geoserver] - Loaded workspace 'sf'
03 Jan 19:40:40 INFO [org.geoserver] - Loaded store 'nyc', enabled
03 Jan 19:40:40 INFO [org.geoserver] - Loaded data store 'nyc'
03 Jan 19:40:40 WARN [referencing.factory] - Axis elements found in a wkt
definition, the force longitude first axis order hint might not be
respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST],
AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
03 Jan 19:40:41 INFO [org.geoserver] - Loaded feature type 'poi', enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded feature type 'nyc'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'poi'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded feature type 'tiger_roads',
enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'tiger_roads'
'poly_landmarks', enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
'giant_polygon', enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'giant_polygon'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded store 'states_shapefile',
enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded data store
'states_shapefile'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded feature type 'states',
enabled
'states_shapefile'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'states'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded data store 'taz_shapes'
'tasmania_roads', enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
'tasmania_cities', enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
'tasmania_water_bodies', enabled
'tasmania_state_boundaries'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded store 'img_sample2',
disabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded coverage 'Pk50095', disabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded coverage 'img_sample2'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded layer 'Pk50095'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded store 'arcGridSample',
enabled
'arcGridSample'
03 Jan 19:40:41 INFO [org.geoserver] - Loaded coverage 'Arc_Sample',
enabled
03 Jan 19:40:41 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded store 'worldImageSample',
enabled
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage store
'worldImageSample'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage 'Img_Sample',
enabled
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded layer 'Img_Sample'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded store 'mosaic', enabled
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage store 'mosaic'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
03 Jan 19:40:42 WARN [imagemosaic.catalog] -
BBOXFilterExtractor::extractBasicProperties(): passed typename is null,
using: mosaic
03 Jan 19:40:42 WARN [imagemosaic.Utils] - Unable to find sample image for
path
/home/lysgaard/oam/geoserver/geoserver-2.2.2/data_dir/coverages/mosaic_sample/sample_image
03 Jan 19:40:42 WARN [gce.imagemosaic] - Unable to find sample image for
path
file:/home/lysgaard/oam/geoserver/geoserver-2.2.2/data_dir/coverages/mosaic_sample/mosaic.shp
03 Jan 19:40:42 INFO [org.geoserver] - Loaded layer 'mosaic'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded store 'oam_elev', enabled
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage store 'oam_elev'
03 Jan 19:40:42 INFO [org.geoserver] - Loaded coverage 'oam_hillshade',
enabled
ureCatalog' while setting constructor argument; nested exception is
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'accessRulesDao' defined in URL
[jar:file:/home/lysgaard/oam/geoserver/geoserver-2.2.2/webapps/geoserver/WEB-INF/lib/main-2.2.2.jar!/applicationSecurityContext.xml]:
Cannot resolve reference to bean 'rawCatalog' while setting constructor
bean with name 'rawCatalog' defined in URL
[jar:file:/home/lysgaard/oam/geoserver/geoserver-2.2.2/webapps/geoserver/WEB-INF/lib/main-2.2.2.jar!/applicationContext.xml]:
Initialization of bean failed; nested exception is
java.lang.RuntimeException: java.lang.IllegalArgumentException: Resource
must be part of a store
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
at
org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at
org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
at
org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
at
org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
at
org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
at
org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
at
org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
at
org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
at
org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
at
org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
at
org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:464)
at
org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
at
org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
at
org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
at
org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:18)
at
org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at
org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at
org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at
org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at
org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at
org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at
org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection.java:152)
at
org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHandlerCollection.java:156)
at
at
at
at
org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at
at
org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.mortbay.start.Main.invokeMain(Main.java:183)
at org.mortbay.start.Main.start(Main.java:497)
at org.mortbay.start.Main.main(Main.java:115)
7172 [main] INFO org.mortbay.log - Opened
/home/lysgaard/oam/geoserver/geoserver-2.2.2/logs/2013_01_03.request.log
7186 [main] INFO org.mortbay.log - Started
SelectChannelConnector@anonymised.com:8080
^C17382 [Shutdown] INFO org.mortbay.log - Shutdown hook executing
17384 [Shutdown] INFO /geoserver - Closing Spring root
java.lang.NoSuchMethodError:
org.apache.commons.logging.LogFactory.release(Ljava/lang/ClassLoader;)V
at
org.geoserver.GeoserverInitStartupListener.contextDestroyed(GeoserverInitStartupListener.java:302)
at
org.mortbay.jetty.handler.ContextHandler.doStop(ContextHandler.java:574)
at
org.mortbay.jetty.webapp.WebAppContext.doStop(WebAppContext.java:485)
at
org.mortbay.component.AbstractLifeCycle.stop(AbstractLifeCycle.java:64)
at
org.mortbay.jetty.handler.HandlerCollection.doStop(HandlerCollection.java:169)
at
at
at
at
org.mortbay.jetty.handler.HandlerWrapper.doStop(HandlerWrapper.java:142)
at org.mortbay.jetty.Server.doStop(Server.java:281)
at
at
org.mortbay.jetty.Server$ShutdownHookThread.run(Server.java:559)
18132 [Shutdown] INFO org.mortbay.log - Shutdown hook complete
View this message in context: http://osgeo-org.1560.n6.nabble.com/What-alternatives-exist-for-dynamic-styling-tp5025446p5025528.html
