Hi to All
As I see there are some parameters in request statements which may be ommitted since Geoserver Has defined some defaults for them. For example the below request :
May be requested as below:
In which the amounts of "tiling=Single tile&antialias=Text only" have not defined. Since the Geoserver has defined default values for those parameters.
The question is this: How can change the default values for these parameters in Geoserver?
Many thanks for your time.
Best Regards
Ali Madad
