when after i install geosever and also i have created the shedule for run the
server and
afert i log off the machine geoserver will stop.... what is the problem for
that.... can any one give me good ans..
View this message in context: http://www.nabble.com/when-server-machine-log-off-geoserver-stop-how-to-control-this-issue-tp22821646p22821646.html
server and afert i log off the machine geoserver will stop.... what is the problem for
Hi Manjula,
assuming this is on Windows, you have to run GeoServer as a Service.
You can either use the Java Service wrapper:
http://geoserver.org/display/GEOSDOC/Windows+Service+Wrapper
or, alternatively, install Apache Tomcat 6.x, which runs as a Service by default, and use the WAR distribution of GeoServer.
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
That happens at least on Windows computer if Geoserver is started as executable program by remote user. It should be run as service instead. If that is your case this might be helpful:
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: Manjula Abey [mailto:manjulaudayanga@anonymised.com]
Lähetetty: 1. huhtikuuta 2009 11:05
Vastaanottaja: geoserver-users@lists.sourceforge.net
Aihe: [Geoserver-users] when server machine log off geoserver
stop how to control this issuewhen after i install geosever and also i have created the
shedule for run the server and afert i log off the machine
geoserver will stop.... what is the problem for that.... can
Sent from the GeoServer - User mailing list archive at Nabble.com.--------------------------------------------------------------
Geoserver-users mailing list
