[Geoserver-users] Which data source for geoserver is fastest?
Hi
First question:
We’re planning to integrate a map which consists of roads, polygons which are symbolized based on attribute.
Now, I don’t know which method is recommend to use with geoserver (performance)?
  • symbolize based on attributes with SLD (lot’s of filters and rules in SLD)
  • change the source data in lot’s of different tables based on their symbolization in geoserver.
  • create views on the tables based on the symbolization (views in oracle, postgis)
  • filter the datasources in geoserver with sql-querys
Second question:
  • Is there a difference in performance if the datasource is: (same structure)
  • shapefile
  • oracle
  • postgis
    Which would be the fastest?
Thank you!
Christian Höhener
On 24/07/2013 8:21 p.m., Christian Höhener wrote:
We're planning to integrate a map which consists of roads, polygons which are symbolized based on attribute.
Now, I don't know which method is recommend to use with geoserver (performance)?
- symbolize based on attributes with SLD (lot's of filters and rules in SLD)
- change the source data in lot's of different tables based on their symbolization in geoserver.
- create views on the tables based on the symbolization (views in oracle, postgis)
- filter the datasources in geoserver with sql-querys
I would say symbolize with SLDs. This way you are sticking with one layer and getting maximum benefit from GWC. In my opinion, that would quickly override any performance issue associated with a complex SLD.
Second question:
- Is there a difference in performance if the datasource is: (same structure)
- shapefile
- oracle
- postgis
I dont have formal benchmarks on this, but some quick tests showed shapefile is fastest to render, but slowest to do any attribute filtering on. If you have a lot of features and/or complex query, this can become very pronounced. Note also that GWC will tend to negate raw rendering speed advantages over time. PostGIS and Oracle are hard to compare because you would need comparable hardware (Our oracle instance is on serious iron) and load (Oracle also takes pounding from multiple applications). By comparison, our PostGIS was relatively unloaded but on a stock server. Frankly, both performed well. Oracle plus SDE though is problematic though in terms of support in geotools. My perception, for what its worth, is that PostGIS is better supported.
Notice: This email and any attachments are confidential.
If received in error please destroy and immediately notify us.
Do not copy or disclose the contents.
Hi Christian,
as Phil, I think the issue is less one of technology. Firstly, what Phil
said implicitly: If the speed is that important tile the layer and access
the tiles not the database. This eases speed problems that may come with a
complicated styling, too. However, prefabricated tiles or tile sets (which
are turned over according to a certain time scale) come with a currency
problem. What is more important for you: Speed or currency.
Think of accessing these tiles as WMTS, no bounding box no internal
calculations which tile conforms to which slice of my picture, you go
directly to the tile.
Network. Any database sitting side-by-side with your server is faster than a
remote one. Same as Phil, I found little differences between Oracle and
PostGIS, with PostGis being a little bit faster. But then - no surprise here
when the DB sits on the same disk. That will always beat what Phil called a
'serious iron', which sits on its own dedicated machine.
Try to simplify filters and put them into one attribute even if that
violates the normality rules. Index the DB, not just the spatial field.
Views will be faster than SLD filters.
'filter the datasources in geoserver with sql-querys', yes definitely, as
far as I know they are essentially views but think also of materialized
views, which are generally faster. However, you need to refresh your views,
when you refresh the data.
Make the symbols as small and simplified as you can i.e. jpg not png. If you
need transparency you're stuck with png. More important than your technology
choice will be the way you structure your data, chop up the sld (if
possible), indexes, styling and tiling.
Christian
____________________________
Dr Christian Maul
Project Manager
Information Services Branch
Department of Sustainability and Environment
Level13, Marland House, 570 Bourke Street
Melbourne 3000
PO Box 500, East Melbourne Vic 3002
Telephone: +61-3-8636 2325
Telefax: +61-3-8636 2813
View this message in context: http://osgeo-org.1560.x6.nabble.com/Which-data-source-for-geoserver-is-fastest-tp5068356p5068562.html
you
technology
Presentation on this topic:
http://demo.geo-solutions.it/share/foss4g2011/gs_steroids_sgiannec_foss4g2011.pdf
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ciao Christian,
please, read below...
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Wed, Jul 24, 2013 at 10:21 AM, Christian Höhener
<christian.hoehener@anonymised.com> wrote:
Hi
First question:
So, only vector data?
(performance)?
postgis)
I would suggest to index and cluster your tables in the DBMS correctly
in order to make queries as fast as possible) and then make a few
quick test with solution 1 against 4.
Second question:
structure)
- shapefile
- oracle
- postgis
If you have many features (at least order of 100k) and you are heavily
filtering them on alphanumeric attributes Shapefile is not an option.
In our experience a fine tuned PostGIS is slightly faster than Oracle
(but honestly who can say to have optimized Oracle finely?).
Quick suggestion, you can hunt down the options to 2 or 3 and then
make some performance tests.
As already indicated GeoWebCache might help in some cases.
You may find some additional hints here:
http://goo.gl/TXJRS
Thank you!
Christian Höhener
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-users mailing list
