On Fri, Apr 22, 2016 at 3:45 AM, eting123 <eting@anonymised.com> wrote:
I have a GeoTIFF image that I added to Geoserver 2.8.1, and white edges
appeared around it when I tried to view it, regardless of what zoom level.
I’ve attached a screenshot of the image
<http://osgeo-org.1560.x6.nabble.com/file/n5262381/screenshotOfImageWithWhiteEdges.png>
. I would have attached the GeoTIFF image too but need to figure out how to
attach it.
We tested the same image in Geoserver 2.2.5, and there was no such problem.
I found this post: https://osgeo-org.atlassian.net/browse/GEOS-7270
My knowledge on GeoTIFF is limited, so I’m not sure if it’s the same
problem. I did try to set -Dorg.geoserver.render.raster.direct.disable=true
and things improved a bit, the white edges only appeared at certain zoom
levels now but not all zoom levels.
This is the call we made when trying to view the image:
http://:8082/geoserver/gwc/service/wms?LAYERS=WV_1&TRANSPARENT=true&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application/vnd.ogc.se_inimage&FORMAT=image/png&SRS=EPSG:4326&BBOX=-90,56.25,-78.75,67.5&WIDTH=256&HEIGHT=256
Any suggestions?
Thank you in advance,
eting.
View this message in context: http://osgeo-org.1560.x6.nabble.com/white-edges-appearing-around-GeoTIFF-image-tp5262381.html
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
