[Geoserver-users] Why do some Geotiffs not display as Geoserver layers
Hello,
I have successfully been able to display a geotiff created by GDAL v. 1.11.0
as a data store in Geoserver. I have another geotiff created by GDAL v.
1.11.0 (different machine) that is in the same directory, has the same
permissions, and same owner/group as the former, but will not display in the
Layer Preview. I get the following error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
&quot;http://davidlary.info:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt;
<ServiceExceptionReport version="1.1.1" > <ServiceException>
      java.lang.IllegalArgumentException: The specified coverageName
20140709is not supported
The specified coverageName 20140709is not supported
</ServiceException></ServiceExceptionReport>
The only thing I do is swap out the as the data store connection URL....
If I run gdalinfo on the two files...I get essentially the same output,
although I am forced to use the --mm and -stats flags for the non-performing
image to see all of the min and max values... I do not need to use the flags
on the performing geotiff.
Any ideas on what is going on??
Thanks!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-do-some-Geotiffs-not-display-as-Geoserver-layers-tp5164850.html
Ciao Victoria,
you should share the gdalinfo on one of the raster that causes problems.
Changing the log level to something like geotools_developer and
sharing a portion of the log would be helpful as well.
Lastly, which version of geoserver are you using?
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Tue, Sep 30, 2014 at 12:26 AM, VictoriaH <bhudspeth@anonymised.com> wrote:
Hello,
Thanks!
Slashdot TV. Videos for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
GEOSERVER VERSION
    Version 2.5-SNAPSHOT
    Git Revision c7886eb21885c88d40029432c3178f88931ed820
    Build Date 27-Aug-2014 17:12
    GeoTools Version 11-SNAPSHOT (rev
6cc70bb4cf9d3f64208a754ee6b83abc20c9359c)
    GeoWebCache Version 1.5-SNAPSHOT (rev
1.5.x/9a50eaa4e44adbe55d071b2861cfc7f62ac44c4c)
The GDALINFO OUTPUT for one of my non-viewable files is:
gdalinfo -mm -stats PM25_monthly_20111000.tif
Driver: GTiff/GeoTIFF
Files: PM25_monthly_20111000.tif
Size is 3600, 1800
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000000000000000)
Pixel Size = (0.100000000000000,-0.100000000000000)
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left (-180.0000000, 90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"N)
Lower Left (-180.0000000, -90.0000000) (180d 0' 0.00"W, 90d 0' 0.00"S)
Upper Right ( 180.0000000, 90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"N)
Lower Right ( 180.0000000, -90.0000000) (180d 0' 0.00"E, 90d 0' 0.00"S)
Center ( 0.0000000, 0.0000000) ( 0d 0' 0.01"E, 0d 0' 0.01"N)
Band 1 Block=3600x2 Type=Byte, ColorInterp=Gray
    Computed Min/Max=1.000,254.000
  Minimum=1.000, Maximum=254.000, Mean=16.180, StdDev=12.675
  NoData Value=0
  Metadata:
    STATISTICS_MAXIMUM=254
    STATISTICS_MEAN=16.17952506657
    STATISTICS_MINIMUM=1
    STATISTICS_STDDEV=12.675263153322
AND, FINALLY THE LOG INFORMATION WHEN I TRY TO DO A LAYER PREVIEW:
2014-09-30 16:40:59,297 WARN [org.geoserver.web] - Unable to reproject layer
pm25_geotiff:20140709to spherical mercator
2014-09-30 16:40:59,304 WARN [org.geoserver.web] - Unable to reproject layer
pm25_monthly:PM25_monthly_19991000to spherical mercator
2014-09-30 16:41:04,293 INFO [org.geoserver.wms] -
Request: getServiceInfo
2014-09-30 16:41:04,294 DEBUG [org.geotools.util] - CRSConverterFactory can
be applied from Strings to CRS only.
2014-09-30 16:41:04,295 DEBUG [org.geotools.util] - CRSConverterFactory can
2014-09-30 16:41:04,296 ERROR [org.geoserver.ows] -
PM25_monthly_19970900is not supported
  at
org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.getMetadataNames(AbstractGridCoverage2DReader.java:965)
  at
org.geoserver.catalog.SingleGridCoverage2DReader.getMetadataNames(SingleGridCoverage2DReader.java:74)
  at
org.geoserver.catalog.CoverageDimensionCustomizerReader.getMetadataNames(CoverageDimensionCustomizerReader.java:246)
  at
org.geoserver.catalog.util.ReaderDimensionsAccessor.<init>(ReaderDimensionsAccessor.java:96)
  at
org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:458)
  at
org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1428)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:626)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
  at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
  at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
  at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at
  at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
  at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
  at
org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:92)
  at
  at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at
  at
  at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at
  at
  at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
  at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
  at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
  at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
  at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
  at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at
  at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
  at
  at
  at
  at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
  at
  at
  at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
  at
  at
  at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
  at
  at
  at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
  at
  at
  at
  at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
  at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
  at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
  at
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
  at
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
  at
  at
  at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
  at
  at
  at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
  at
  at
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
  at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
  at java.lang.Thread.run(Thread.java:701)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-do-some-Geotiffs-not-display-as-Geoserver-layers-tp5164850p5165090.html
Error message says that image can't be re-projected into spherical mercator (EPSG:3857). Try with some WMS client (QGIS, OpenJUMP etc.) if you can show it in EPSG:4326. Gdalinfo shows that image covers the whole world including the poles but EPSG:3857 is only valid between 85.06°S and 85.06°N http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::3857&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=EPSG:3857
If image displays in EPSG:4326 try to crop it and clip off the polar regions and see if that helps.
-Jukka Rahkonen-
________________________________________
VictoriaH wrote:
GEOSERVER VERSION
Size is 3600, 1800
GEOGCS["WGS 84",
    DATUM["WGS_1984",
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=BAND
Corner Coordinates:
  NoData Value=0
  Metadata:
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
        at
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Hello, thank you for looking at this. First, I have no idea why the server is
trying to re-project this to EPSG:3857. Could I have mistakenly made a
setting that is trying to do this. I only want to view in 4326. If I look at
the image in QGIS, it displays without problems. If you compare the gdal
output of this image to the gdal output from another image that does display
in the layer preview, the outputs are identical (see first email in this
thread). The two images were created with the same series of GDAL commands,
and have the same gdal diagnostics, but one will not display. I don't know
where the EPSG:3857 came from.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-do-some-Geotiffs-not-display-as-Geoserver-layers-tp5164850p5165341.html
Hi Victoria,
any chance you could share the tiff image in question, place it somewhere it can be downloaded?
and have the same gdal diagnostics, but one will not display. I don’t know
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Thanks for helping Andrea,
I have two files to download by FTP:
The first one displays correctly in the Layer Previewer and in my OpenLayers
based website:
ftp://edacftp.unm.edu/outgoing/pub/bhudspeth/20140709.tif
The second one will NOT display in either.....
ftp://edacftp.unm.edu/outgoing/pub/bhudspeth/PM25_monthly_19971000.tif
Thank you!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-do-some-Geotiffs-not-display-as-Geoserver-layers-tp5164850p5165363.html
