[Geoserver-users] Why do some Geotiffs not display as Geoserver layers
Hi Victoria,
Your image actually shows but it is so dark that you can't see it. The average value on greyscale 0-255 is only 14.2
gdalinfo PM25_monthly_19971000.tiff -stats
Metadata:
  STATISTICS_MAXIMUM=169
  STATISTICS_MEAN=14.204098037538
  STATISTICS_MINIMUM=1
  STATISTICS_STDDEV=8.2208826615229
Quick and dirty fix is to rescale image with GDAL and stretch the beginning of the scale 0-40 -> 0-255
gdal_translate -of GTiff -co tiled=yes PM25_monthly_19971000.tif scaled.tif -scale 0 40 0 255
Proper way with Geoserver is to publish the image through a SLD that does the stretch on-the-fly. I would guess that ContrastEnhancement Histogram could suit for this image http://docs.geoserver.org/stable/en/user/styling/sld-reference/rastersymbolizer.html
-Jukka Rahkonen-
VictoriaH wrote:
Thanks for helping Andrea,
I have two files to download by FTP:
The first one displays correctly in the Layer Previewer and in my OpenLayers
based website:
ftp://edacftp.unm.edu/outgoing/pub/bhudspeth/20140709.tif
The second one will NOT display in either.....
ftp://edacftp.unm.edu/outgoing/pub/bhudspeth/PM25_monthly_19971000.tif
Thank you!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-do-
some-Geotiffs-not-display-as-Geoserver-layers-tp5164850p5165363.html
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer Achieve PCI
DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports Are you Audit-
Ready for PCI DSS 3.0 Compliance? Download White paper Comply to PCI DSS
3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktr
k
Geoserver-users mailing list
I can look at this image in QGIS and it looks fine. I cannot stretch the
values, because the values are meaningful for interpretation, and are
handled correctly by my SLD. When I try to look at the image in the
GEoserver administration layer preview, it throws an error. I have even
clipped the image so it does not extend beyond N and S 85 degrees (so it can
be re-projected in the Layer preview). I have another image that does
display in the preview. Both the good image and the bad image give exactly
the same Gdalinfo output. The good image displays even though it extends all
the way to 90 north and south. I have tried all of the suggestions in this
post thread, but I still get an error. I don't understand why one will
display correctly, and the other will not.
2014-10-02 14:10:18,569 WARN [org.geoserver.web] - Unable to reproject layer
pm25_geotiff:20140709to spherical mercator
2014-10-02 14:10:18,577 WARN [org.geoserver.web] - Unable to reproject layer
pm25_monthly:PM25_monthly_19991000to spherical mercator
2014-10-02 14:10:20,797 INFO [org.geoserver.wms] -
Request: getServiceInfo
2014-10-02 14:10:20,798 DEBUG [org.geotools.util] - CRSConverterFactory can
be applied from Strings to CRS only.
2014-10-02 14:10:20,799 ERROR [org.geoserver.ows] -
java.lang.IllegalArgumentException: The specified coverageName
PM25_monthly_19970900is not supported
  at
org.geotools.coverage.grid.io.AbstractGridCoverage2DReader.getMetadataNames(AbstractGridCoverage2DReader.java:965)
  at
org.geoserver.catalog.SingleGridCoverage2DReader.getMetadataNames(SingleGridCoverage2DReader.java:74)
  at
org.geoserver.catalog.CoverageDimensionCustomizerReader.getMetadataNames(CoverageDimensionCustomizerReader.java:246)
  at
org.geoserver.catalog.util.ReaderDimensionsAccessor.<init>(ReaderDimensionsAccessor.java:96)
  at
org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:458)
  at
org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1428)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:626)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
  at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
  at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
  at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
  at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
  at
org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:27)
  at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
  at
  at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
  at
org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:70)
  at
org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:70)
  at
org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:92)
  at
  at
org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
  at
  at
  at
org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
  at
  at
  at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:311)
  at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:68)
  at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:116)
  at
org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
  at
org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:72)
  at
org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:91)
  at
org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:323)
  at
  at
org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:113)
  at
  at
  at
  at
org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:53)
  at
  at
  at
org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilter(BasicAuthenticationFilter.java:150)
  at
  at
  at
org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:82)
  at
  at
  at
org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:87)
  at
org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:52)
  at
  at
  at
  at
org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:173)
  at
org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:134)
  at
org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
  at
org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:259)
  at
  at
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:75)
  at
  at
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
  at
  at
  at
org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:47)
  at
  at
  at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:43)
  at
  at
  at
org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
  at
  at
  at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
  at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
  at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
  at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
  at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
  at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
  at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
  at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
  at java.lang.Thread.run(Thread.java:701)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Why-do-some-Geotiffs-not-display-as-Geoserver-layers-tp5164850p5165622.html
