[Geoserver-users] Why does KML link give me KMX ?
Hello,
I am trying to include a layer in OpenLayers. I have set up the POSTGIS connection to my layer but when I click on the DEMO page and KML I get downloaded a KMZ file.
http://localhost.no:8080/geoserver/wms/kml?layers=kulturminner_ns:boplass
I checked on another geoserver and there the link downloads a KML file. What am I doing wrong? Is it something to do with the proxy.cgi?
/asle
Hi Asle,
it is actually a KML file, it just has the .kmz extension. We used to compress the KML output by default, I guess we don't anymore. Could you file a jira issue?
(The "wms/kml" part of the URL does not imply the format, it only tells GeoServer this is a KML-related request.)
-Arne
Asle Benoni wrote:
Hello,
/asle
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
The KML reflector is optimized for use with Google Earth, which means
that it returns a compressed kml file with a regionated hierarchy
whenever possible. If you want the raw XML, you can either:
* request a non-regionated, non-compressed KML file by appending
'&mode=download' to your request parameters, or
* go through the "real" WMS (geoserver/wms) and set format=kml.
Hope this helps.
David Winslow
OpenGeo - http://opengeo.org/
On Thu, 2009-03-26 at 14:05 +0100, Arne Kepp wrote:
Hi Asle,
file a jira issue?
-Arne
Asle Benoni wrote:
> Hello,
> /asle
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
I understand that I am using GeoServer 1.7.3 and that the output is KMZ always?
The KMZ file I download from the GeoServer demo page zooms to the correct area when I open it in Google Earth. But all the markers were gone! So I found out that I had put this in Config-Server:
Proxy Base URL: mydomainame.no:8080
When I left that field in config empty I get the same KMZ file but now with correct markers. I am confused as to how this affects the serving of KML/KMZ to OpenLayers. Here is the code from my html which shows no data, only the name of the layer.
var kml =new OpenLayers.Layer.GML(“KML kulturminner”, “http://naturkart.no:8080/geoserver/wms/kml?layers=kulturminner_ns:gravminne&format=application/vnd.google-earth.kmz+XML&transparent=true&”,
format: OpenLayers.Format.KML,
formatOptions: {
extractStyles: true,
extractAttributes: true
And I can see it is loaded in Firebug with this request:
url http://naturkart.no:8080/geoserver/wms/kml?layers=kulturminner_ns:gravminne&format=application/vnd.google-earth
And this response:
<?xml version="1.0" encoding="UTF-8"?> kulturminner_ns:gravminne 1 1 onStop 1 11.242907598744864 59.337531461714526 0 178137.16338200175 0 0 clampToGround
I found out that whe
Den 26. mars. 2009 kl. 14.57 skrev David Winslow:
  • request a non-regionated, non-compressed KML file by appending
    ‘&mode=download’ to your request parameters, or
  • go through the “real” WMS (geoserver/wms) and set format=kml.
Hope this helps.
David Winslow
Hi Asle,
compress the KML output by default, I guess we don’t anymore. Could you
file a jira issue?
(The “wms/kml” part of the URL does not imply the format, it only tells
-Arne
Asle Benoni wrote:
Hello,
/asle
Aha. I think I found out the one with Proxy Base URL. I forgot the “http://” - Now my KMZ files load correctly in Google Earth at least!
/asle
Den 26. mars. 2009 kl. 16.10 skrev Asle Benoni:
formatOptions: {
And this response:
Hope this helps.
David Winslow
Hi Asle,
file a jira issue?
-Arne
Asle Benoni wrote:
Hello,
/asle
Geoserver-users@anonymised.comrge.net
