On Thu, Aug 6, 2015 at 4:14 AM, Like-Self <like_self@anonymised.com> wrote:
Hi
I installed the control-flow plugin on GeoServer 2.5.1, and created
controlflow.properties below:
ows.global=5 and timeout=60.
Since I suppose the log did not indicate appropriate information, I’ve
had double check in the source. Following content was returned after a
request was accomplished: 'Running requests: 8, processing through flow
controllers: 6'.
Considering it was set as 5 for the concurrent request in config file,
could you please confirm why the source implied it as 8? Does it mean the
amount of running requests exceeded the setting?
Hum.. unsure... it could be a bug, but releases from 2.5.x are unsupported,
you should at least
try 2.7.x (2.6.x is becoming unsupported in less than 2 weeks, don't bother
trying it out, the
amount of changes in 2.6.x is pretty much cast in stone by now, every
developer is rushing
to get the features they need in 2.8-beta, which will get in feature freeze
the 18th).
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
