I'm using windbarbs with following definition:
<WellKnownName>windbarbs://default(<ogc:PropertyName>speed</ogc:PropertyName>)[m/s]</WellKnownName>
Everything works as expected except the "Preview legend" command that throws an error:
ERROR [wicket.RequestCycle] - The specified mark
strConcat([strConcat([windbarbs://default(], [speed])], [)[m/s]]) was not found!
Any ideas?
Regards
Maciej
2015-10-01 09:47:21,238 ERROR [wicket.RequestCycle] - The specified mark strConcat([strConcat([windbarbs://default(], [speed])], [)[m/s]]) was not found!
java.lang.IllegalArgumentException: The specified mark strConcat([strConcat([windbarbs://default(], [speed])], [)[m/s]]) was not found!
at org.geotools.renderer.style.SLDStyleFactory.createMarkStyle(SLDStyleFactory.java:747)
at org.geotools.renderer.style.SLDStyleFactory.createPointStyle(SLDStyleFactory.java:711)
at org.geotools.renderer.style.SLDStyleFactory.createPointStyle(SLDStyleFactory.java:576)
at org.geotools.renderer.style.SLDStyleFactory.createStyleInternal(SLDStyleFactory.java:415)
at org.geotools.renderer.style.SLDStyleFactory.createStyle(SLDStyleFactory.java:362)
at org.geoserver.wms.legendgraphic.BufferedImageLegendGraphicBuilder.buildLegendGraphic(BufferedImageLegendGraphicBuilder.java:400)
at org.geoserver.wms.web.data.AbstractStylePage$7$1.getData(AbstractStylePage.java:303)
at org.apache.wicket.markup.html.DynamicWebResource$ResourceState.getLength(DynamicWebResource.java:89)
at org.apache.wicket.markup.html.DynamicWebResource$1.length(DynamicWebResource.java:241)
at org.apache.wicket.request.target.resource.ResourceStreamRequestTarget.configure(ResourceStreamRequestTarget.java:241)
at org.apache.wicket.request.target.resource.ResourceStreamRequestTarget.respond(ResourceStreamRequestTarget.java:150)
at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:105)
at org.apache.wicket.RequestCycle.respond(RequestCycle.java:1267)
at org.apache.wicket.RequestCycle.step(RequestCycle.java:1334)
at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
at org.apache.wicket.protocol.http.WicketFilter.doGet(WicketFilter.java:484)
at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:138)
