[Geoserver-users] Windows GeoServer service won't start
Hi
I am running into issues getting a GeoServer windows service to start (ever) - I get a 1053 error.
Digging back I can see this is related to the wrapper, which throws the following error -
ERROR | wrapper | 2014/05/06 06:20:42 | Unable to expand “Path”: A device attached to the system is not functioning. (0x1f).
I am not sure if this in turn might related to an environment setting or something else? The Java_home path looks sensible - C:\Program Files (x86)\Java\jre7.
Note if I install GeoServer via the manual start/stop route it works okay.
Any suggestions as this is proving v.frustrating (last Windows installation I did worked fine!)
Chris
Hi Chris,
the error seems to suggest that your environment variable PATH contains a path to a not existing / not working device, maybe a removable one?
Try to check and eventually fix the system or user PATH.
Mauro
2014-05-06 7:31 GMT+02:00 Chris Jackson <webturtles@anonymised.com>:
Hi
Chris
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now
http://p.sf.net/sfu/perforce
Geoserver-users mailing list
Hi Mauro
Yeah, just gone through the path environment variable and cleared out some non-existent paths and viola, GeoServer is now up and running.
Many thanks
Chris
On 6 May 2014 08:13, Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Hi Chris,
Mauro
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via Poggio alle Viti 1187
Hi
Chris
